01-22-2015, 03:16 PM | #15 | |
Drives: 2010 Camaro SS ls3 Join Date: Oct 2014
Very well said. Honestly it's not the amount of money it costs to replace them it's more so having to do the extra work removing the heads. I looked at the previous link a few posts ahead and it explains how to remove the heads, but is there any special procedure in changing the lifters? |
01-22-2015, 03:33 PM | #16 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I put an LS6 cam in my LQ4 engine with LS6 heads at around 90. Now at 155k. Did not swap in new lifters but it certainly would not hurt.
I was going to rebuild it with forged internals, but ended modding the Camaro and have not been able to stop.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-22-2015, 03:38 PM | #17 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I can see keeping the stock lifters and not touching those until you do a set of ported heads.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-22-2015, 03:38 PM | #18 | |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
"OPTIONAL CAM SWAP: Now, if you want to do a cam swap, this is the time. Unbolt the plastic pushrod guides from the block and the lifter should come out with them. Set them aside keeping them in the exact same order you pulled them out. Pull the crank pulley, unbolt the timing chain cover, unbolt the cam gear, unbolt the cam retainer plate, then pull out the cam and slide the new one in. For more details on a camswap you can read MBasketts site here:" There are 8x plastic "lifter trays" that hold the lifters. After you pull the heads off, you will see the Lifter trays at the tops of each cylinder. They are held in by 1x bolt. Take the bolt out and the tray will come out with the lifters attached. If you're only doing a cam swap and NOT removing the heads, you will need to stick a 5/16" wooden dowel that is longer than the length of the block into the lifter holder opening's in the front of the block. There is 1x per side (2 total) and they will hold the lifters in the 'UP' position as you slide the cam out. After the new cam has been installed in the block, you can remove the dowels. It's very straight forward. READ THIS to get more familiar with the HOW TO of the cam swap. Minus all the car specific stuff, its a LOT easier to do a cam swap in a 5th gen compared to a 4th gen.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
01-22-2015, 04:28 PM | #19 | |||
Do both the lifters and trays have to be replaced? How much are they and where do I get them? |
01-22-2015, 04:49 PM | #20 |
I see it now. The heads come off first to replace the lifters while the cam is still in the car the lifters can't fall? Then once that's done I'd go into doing the cam swap.
01-22-2015, 05:05 PM | #21 |
01-22-2015, 05:14 PM | #22 |
Be sure to change out the timing chain tensioner to an LS2 style dampener. This is a pic of the last motor I pulled apart. After that plastic breaks there is some spring steel that can come out all cause all kinds of problems.
01-22-2015, 06:48 PM | #23 |
Already have one on the list but thanks for the tip
Thread Tools | |
