View Poll Results: Would you have added an LS7 for $5K?
Yes 101 86.32%
No 16 13.68%
Voters: 117. You may not vote on this poll
Old 02-25-2015, 09:51 AM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
LS7 1LE
Would you have gotten your 1LE with the LS7 if it was a $5K option? I know I would've, mine would be a 1SS, 1LE, Recaros, and LS7 it'd only be around $45K MSRP. Too bad GM didn't do that, I guess I have to keep building the LS3 then.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 02-25-2015, 10:08 AM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Of course!!
As yesterdays thread about this discussed, it would likely not be possible at such a low additional cost, but we can dream.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 02-25-2015, 10:25 AM   #3
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
too many worries
The LS7 is a monster. I had one in my 2009 C6 Z06, and it was the fastest car I most likely ever owned. My only worry was there are, and still is, an issue with the valve guides prematurely wearing, eventually causing a intake valve to drop into the combustion chamber. Since everything is aluminum on this engine, it usually blows out a cylinder liner, breaking the block... causing the entire engine to be a complete right off. While under warranty I was worried, but knew I was covered as long as I didnt modify it. After the drive train warranty ended, I sold the car. The crate engines are $15K. There are a lot of threads covering this known issue, both in the Z28, and C6 forum. Guess if you want to play, you have to pay. It was just too much money for me to worry about, cause if the engine went the car would have been worthless w/o the replacement engine.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 02-25-2015, 10:27 AM   #4
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
seeing that the LS7 crate motor is $15k from GM performance parts it would still be a cool option.
GM really needs to offer the A6 for the 1LE.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 02-25-2015, 10:50 AM   #5
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
Even a dry sump LS3 with a few more ponies would have been a nice option!
Shark72 is offline   Reply With Quote
Old 02-25-2015, 10:52 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I saw this exact set up last time I was out at the Street of Willow race track. That 1LE was a fast mofo and sounded great around the track.
I have no idea how much he paid to have the LS7 put into his 1LE.
Mods:
Old 02-25-2015, 11:03 AM   #7
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Do you mean A8 like the Corvette or a 6 speed version for the Camaro.
gajagfan is offline   Reply With Quote
Old 02-25-2015, 11:04 AM   #8
01pewterz28
#TeamBeckyD
A8 is not available in the current Camaro.
#TeamBeckyD
Old 02-25-2015, 11:11 AM   #9
gajagfan
gajagfan's Avatar
I know. So you are asking for a 6 speed version with the features of the Corvettes A8?
Old 02-25-2015, 11:12 AM   #10
01pewterz28
#TeamBeckyD
For the current model year but moving forward to the 6th Gen A8 yes.
#TeamBeckyD
Old 02-25-2015, 11:23 AM   #11
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Wait.....you are saying you want an automatic track car?
Old 02-25-2015, 12:28 PM   #12
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Sure ,im in for that . AT THE RISK OF GETTING FLAMED , what about a duel clutch like the PDK and a LT version of the 427 with no valve problems ? Or a Twin turbo LT.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 02-25-2015, 12:42 PM   #13
gajagfan
gajagfan's Avatar
As it sits right now, the A8 Vette is faster than the manual Vette. Like it or not, that is the facts at this point. And a dual clutch deal is nothing to sneeze at either. No one at the Rolex 24 at Daytona this year was using a manual clutch.....those were some pretty nice track cars!
Old 02-25-2015, 01:22 PM   #14
1leNPP
Drives: 1LE , 1SS , NPP
My car is a DD, the LS7 have a valve guild wear problem . I would only get a LS7 motor car that a toy car you dive on the week ends only.
1leNPP is offline   Reply With Quote
