03-02-2015, 06:05 PM | #1 |
Auxiliary Low Profile USB Charger
So I just picked up two of these low profile auxiliary chargers. I like the hidden aspect of the 2014 Camaro's aux power port, but the USB sticking out all the time would drive me nuts.
I eyeballed it as best I could, and there is about 2-3mm free under the cover. These just might do the trick! http://www.ebay.com/itm/370991014250...%3AMEBIDX%3AIT I'll post pictures once I get it, and how it turned out. |
03-02-2015, 07:21 PM | #2 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
So If I understand correctly, you want this to fit inside the power port and the door can still close? What about if you need to remove it?
03-03-2015, 11:10 AM | #3 |
I wouldn't need to, I use my phone as a GPS and thats the only thing I would need to plug in. I do see what you saying it would be a pain in the ass to remove if I did have to change it. I keep everything simple
03-03-2015, 11:50 AM | #4 | |
What happens is the fuse in the adapter goes? Your going to need a way to remove it. Maybe tie a piece of fish like around it so you can remove. I'm not knocking it, I think it's a good idea, but you should have a way to pull it out |
03-03-2015, 06:59 PM | #5 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I use these type of USB chargers in my cars. They're pretty easy to remove when you need to.
03-03-2015, 07:18 PM | #6 |
03-06-2015, 06:58 PM | #7 |
Hmm...Something Clever
Drives: Blac on Blaq on Blak 2012 Camaro LS Join Date: Dec 2009
Gawd I love when old people meet new technology
Adjustments: 20% tint all around, Emblem Pros Dash plaque, Rockford Fosgate P-300/12 |
03-06-2015, 07:04 PM | #8 |
03-06-2015, 07:16 PM | #9 |
Its pretty easy to remove. You can pry it up with you fingernail around the top flange. Or just grab the plugged in end of the USB cable, then slightly twist and pull up at the same time.
03-06-2015, 07:21 PM | #10 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
03-06-2015, 08:07 PM | #11 |
DrDivo
I have one. It does NOT allow the lid to fully close.
Other issue, it's not very high voltage. It'll power something that doesn't require much power, but most high end Android phones and anything from Apple won't charge with it. Sent from my iPad using Tapatalk HD
Best regards, DrDivo
03-06-2015, 08:41 PM | #12 |
Different brands have different charging amperages. A lot are only one amp, while some are 2.1 and more. I have a Belkin that is 2.1amps and a noname brand I found at Frys Electronics that is 3.2 amps. Both charge my Note 2 pretty good.
03-07-2015, 10:11 AM | #13 | |
Well that's a bust. Would have been nice if they put a usb port right there with a little door. Maybe the 6th gen. |
03-07-2015, 10:23 AM | #14 | |
Now you got me thinking. Thanks, like I needed another project.
Thread Tools | |
