Old 03-15-2015, 07:13 PM   #1
yella terra
Drives: 2011 Camaro SS L99
Good Street Tires
I'm buying some new 20x9 and 20x10.5 rims and trying to decide what rims that will have good wet traction as I live in Louisiana. I also will be pushing around 500 rwhp through a stalled car. What tires do you recommend for front and rear that will help me get good traction on the street. thanks
yella terra is offline   Reply With Quote
Old 03-15-2015, 07:32 PM   #2
yella terra
I was thinking about doing nittos 555 275/40/20 up front and nittos 555R 305/35/20 in the rear but I'm worried that they will throw some lights on? Or invos good tires?
Old 03-15-2015, 10:02 PM   #3
HALOBRYAN
Drives: 2012 Camaro LT2
You wont have good traction with the 555r in the rain, plus they will wear out quickly.
I would go with the invos if you want traction in the rain.
HALOBRYAN is offline   Reply With Quote
Old 03-15-2015, 11:59 PM   #4
yella terra
Yea I'm gonna see if I can maybe pick a used set of invos from another member to see how they do. I appreciate the information.
Old 03-16-2015, 12:03 AM   #5
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Invos might work pretty well, I would be surprised if they hold 500 RWHP though. I have a nearly worn out set on my car making 420 RWHP and they will hold in first, but I can tell they're spinning some.
They do great in the rain though and even in the cold. I would avoid any drag radial, they really aren't intended for daily driving, but they will grip for sure.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-16-2015, 09:08 AM   #6
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I would suggest Michelin Pilot Super Sports. In my opinion there is no better tire for a daily driver high horsepower car that wont see snow or very low temps(LA).
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 03-16-2015, 10:28 AM   #7
yella terra
I will have to check into those Michelin Pilot Super Sports. I have seen alot of people running those. I appreciate the help.
Old 03-18-2015, 12:42 PM   #8
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
They don't have those for the rear, do they?
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 03-18-2015, 01:45 PM   #9
Destructo09
The closest size to stock they make is 275/35R20 which would be a shorter sidewall.
I think they make a 255 wide front that might work also on the front if you didn't want to run 275 all around.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 03-18-2015, 02:13 PM   #10
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
With 500whp I'd steer clear of invos ... If not some sort of radial(DR) I'd only go with 888s or PP's.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
BooSSted is offline   Reply With Quote
Old 03-18-2015, 02:20 PM   #11
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
Really does depend on what your end goal is but with 500 RWHP you will be very pressed to get any traction on the street without a DR on the rear! I am running the Nitto NT5's on the rear with the "stock" on the front and, unless I use "comp" mod on the street, I will smoke the tires off through second gear and I am at 434 RWHP.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 03-18-2015, 04:17 PM   #12
bob2010ss
bob2010ss's Avatar
Drives: Turbocharged 2010 GLOSSY NARDO GREY
i had 555rs on the back of my car last summer, to be honest i think anything i put on the back will light up in first......im looking and hoping for something that will grb a hold at some point in 2nd
[/SIGPIC]2010 2SS Turbonetics STAGE II 76 mm Single Top Mount
Bigger Pump, Bigger Injectors, No Cats, Gm Performance Cat Back CAMMED, METH and at 10lbs 630rwhp/ 690 ftlbs
SPI Built and Tuned
Eibach Suspension and beeeeeefed up axles!!!
and a whole lotta whooooooosh
oh and those are MT Drag Radials on the back
bob2010ss is offline   Reply With Quote
Old 03-18-2015, 04:39 PM   #13
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
If you drag race your car stay away form the Invos. I took mine off the next day after a terrible time trying to get traction at the strip. Pilot super sports will hold over 500 if you heat them up and are great to daily drive on (besides snow but thats any performance tire)
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
