Old 03-18-2015, 11:58 AM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
3.91 gears on L99 2010 Camaro ss
I know people on here recommend the 3.73 gears for the auto but what is the advantage over the 3.91 gears? In the future I'm going to get a carbon fiber driveshaft, camshaft, and get ported heads so will the 3.73 still be the better option than the 3.91s after installing all these? I'm planning on staying naturally aspirated as well.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 03-18-2015, 12:04 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Did it on mine and love the 3.91s -- the auto is geared deeper so 1st and 2nd are a challenge but, I did love them. Really wakes up the car. The 3.91's I had were from GM so they were designed and meant for the car....
I have 3.45s now as I'm SC'd -- but before I changed them, they would just spin the wheels with the SC -- really something...
-Don
747 RWHP 794 RWTQ
Old 03-18-2015, 12:26 PM   #3
krisprz2010camaross
-Don
Yah the gears I'm looking at are the ones from the 1le so they are gm as well. Would you have kept the 3.91s on you if you didn't go supercharged?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 03-18-2015, 12:47 PM   #4
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
Love my 3.91 gears. Vast improvement over the stock gearing. Would never go back, and I have no aspirations of going SC....
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 03-18-2015, 01:10 PM   #5
krisprz2010camaross
So it really is noticeable on all modes drive, sport, and manual?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 03-18-2015, 01:21 PM   #6
45THanniversarySS
Builder of fast cars
45THanniversarySS's Avatar
Drives: 2012 2SS 45TH Anniverary Edition
what is you end goal with the car? with heads, cam, stall (about 3600), 3.91 gears, suspension mod, and a set of radials (and a tune to match of course) you will be running 11's all day...with the right driver it has been known to touch top of 10's. but im sure your not looking for that aggressive right lol? right? if your looking to bring it alive 3.73 will do it but those 3.91 will help trap better numbers with a slightly higher RPM drive...just dont expect to much top speed with 3.91 gears, maybe around 165mph with that build...but you will get there fast
45THanniversarySS is offline   Reply With Quote
Old 03-18-2015, 01:40 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I have 1LE 3.91's in my car. They are a lot of fun.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 03-18-2015, 01:44 PM   #8
hammdo
hammdo's Avatar
Yep and not looked back. It was a great upgrade. I wanted an auto 1LE, then migrated to ZL1 parts, and now I have a combo!
-Don
747 RWHP 794 RWTQ
Old 03-18-2015, 01:51 PM   #9
krisprz2010camaross
-Don
I guess I'll get the 3.91 gears then. Do you know around much it will cost to install and recalibrate the speedometer? I'm also gonna have my driveshaft and zl1 fuel pump installed at the same time as the gears.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 03-18-2015, 02:11 PM   #10
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
What ever gear ratio you choose, do not let anyone talk you into buying Richmond Gears!!!! They worked good on the street for me but once at the drag strip where traction is great....they completely blew apart! Go with GM or AAM gears, I went with the 3.73 AAM gears and have been to the track around 6 different times, pulled 1.8 60 ft. times and the gears are still working great! The Richmonds blew up on the 4th pass, on the line, the first time I was at the track with them!
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 03-18-2015, 02:21 PM   #11
krisprz2010camaross
Wow good to know, thanks.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 03-18-2015, 02:27 PM   #12
Dave Coyle
Dave Coyle's Avatar
Just don't want you to go through the headache I did! It took out the housing too!!! Richmond did not do anything because they said that they only warrantee their gears on the street and once you go to the track you are not under warrantee! I even told them the box the gears came in stated Street/Strip but got nowhere!!!
434RWHP/403RWTQ
Old 03-18-2015, 04:58 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Looking to get mine down at a dealership in AK that does the swap for about a grand with a speedo recal an a warranty
An talked to a guy here locally and he said they did his on a Saturday...
Old 03-18-2015, 09:28 PM   #14
ccb1975
ccb1975's Avatar
Drives: 2010 WHITE SS
just had my 3.91 last week. dealership charged 800.00. no speed cal tho..they said that they couldn't do the cal cause they wasn't aloud to.
ccb1975 is offline   Reply With Quote
