03-21-2015, 02:44 PM | #1 |
Drives: 2015 Camaro RS 2LT AGM Join Date: Aug 2014
Rock guards for us with Ground Effects Please
Yes I know this has been discussed and I spent hours searching and reading on the forum. However, I do not have a Z(obviously) so mine does not come with any partial rock guards. I just have a 2LT that has ground effects package!!!! I want to know if someone has a Camaro with Ground Effects package that came with no factory rock guards...... what have you used. Has anyone found front and backs that fit on ground effects made by GM???
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions) |
03-21-2015, 05:26 PM | #2 |
RPI is the only manufacturer of guards for OEM ground effects that I know of. However the rears do not fit, only the front. I do not have ground effects for my 2012 2SS, but the front guards were all I needed as they stopped the chipping process on the doors and "gill" area's completely.
Here's your link. http://www.rpidesigns.com/shop/item.aspx?itemid=3303 |
03-21-2015, 05:33 PM | #3 | |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
These will consist of Front And Rear Wheel Well Canards at the Front of Each Well and Rock Guards at the Rear of the Well. Look for our Coming Thread.
03-22-2015, 08:44 AM | #4 |
Hurry
I'm in for two sets if they work F&R with factory GFX!!!
03-22-2015, 09:39 PM | #5 |
Drives: 2012 Join Date: May 2012
Contact Showstopper..... He is a vendor here and does amazing stuff. I believe he has them ready to go.
"Madness, as you know, is a lot like gravity, all it takes is a little push."
03-23-2015, 11:36 AM | #6 |
Yea, I talked to show stoppers, they said fronts will work but they have nothing for the rears.
03-23-2015, 12:05 PM | #7 | |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
Please confirm that these will work for cars that have the ground effects package... Please note that if they fit ZL1, 1LE, etc, they will not fit ground effects cars. |
03-23-2015, 12:07 PM | #8 | |
I have the new OEM front rock guards, and it works fine. The new style and old style OEM rears will not work with the GFX. I have even tried modifying them, and no dice- I thought I could get them to work, but did not look presentable at all. |
03-23-2015, 02:00 PM | #9 |
Do you have a pic to share of the OEM front rock guards from GM? I guess since no one has the rears for GFX I would decide from Showstopper or GM for the front at least.
03-26-2015, 11:43 PM | #10 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
I'm getting the ZL-1 rock guards for the front. I know the rear ones won't fit with the GFX, but the fronts will. I haven't found a need for rock guards on the rear. I just put clear bra on the GFX right behind the wheel well and wrapped just to the corner. I have no chips on rear fender or GFX. And this is with 315's on 11 inch wheels. I do have chips on gills and behind front fender and lower part of doors.
Meh
03-27-2015, 02:24 PM | #11 | |
For the rock chips you have, Dr colorchip works great on smaller chips and road rash. For larger chips the Langka works well. |
03-30-2015, 10:59 AM | #12 |
Called several dealers around my area and theyt only find the molded guards which obviously will not work on ground effects. I found these. It says it not to use with factory ground effects yet in the picture it looks like there are ground effects on the car. Anyone bought these?
http://www.shopchevyparts.com/exteri...-92281887.html
03-30-2015, 11:33 AM | #13 |
That photo has the ZL1 Rockers or Special Edition Rockers which are the same.
Thank you Kurt Robinson Aero Sport Concepts
03-30-2015, 01:21 PM | #14 |
anyone have these??
http://zl1addons.com/index.php/produ...l1-rock-guards
