![]() Drives: 11 BLK 2SS/RS Join Date: Feb 2015
Will these LEDs work to replace the factory halo LED?
http://www.ebay.com/itm/Lot-5PCS-3W-...item566c481c75
here is the link, are these a good size and a good option if anyone knows?
BUMBL Z
it looks like they might, you may need to solder leads to them though
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Dont get them, they will not fit with out modding the halo ring, you want a flat RGB LED like that one, lens has to be flat.
#4 | |
Flat as in like these? Thanks!
http://www.camaro5.com/forums/showthread.php?t=255417
This is the DIY RGB HALO THREAD and the LEDs they are using DONT have a flat lens
#6 |
![]() Drives: Blue Ray 2SS Join Date: Jul 2013
Doesn't someone they make a simple plug and play module that can change the color of the LED that doesn't require baking? I think I remembered seeing one a while back.
Paul |
#7 |
HTCC Membership Director
Drives: 2013 RS Camaro Join Date: Jan 2014
Night owl sells a kit that doesn't require baking the headlights
#8 |
I'm a good handyman so why pay 350+ when I can pay less than 30...so no I'm not interested in the Nightowl, just want advice on the LED
#9 |
![]() ![]() ![]() Drives: 2011 2SS Join Date: Jan 2013
The last ones look like they would work. What are you planning on controlling them with? Good luck.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 2SS Join Date: Apr 2011
The last eBay link is just for the circuit board. No LED.
#11 | |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
#12 | |
#13 |
Hold out till the am I will post some LEDS
#14 |
Thanks Ofer, the DIY calls for LEDs that look like these http://m.ebay.com/itm/320938690780?nav=SEARCH
Except the ones that the forum users like CamaroLS posted have been unavailable from the seller for over a month now. I also already have 22 ohm 25 watt resistors as you had recommended to one of the users in the DIY guide.
