Old 04-04-2015, 07:00 PM   #1
djoker08
HTCC Member
djoker08's Avatar
Drives: 2018 ZL1 1LE HBM
Door insert install problem
I tried to install my door inserts today but they would not fit on the front of the door where it meets with the dash trim. Has anyone else had this problem or have any suggestion?
djoker08 is offline   Reply With Quote
Old 04-04-2015, 07:15 PM   #2
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
Pictures of the problem?
justjoshin is offline   Reply With Quote
Old 04-04-2015, 11:28 PM   #3
djoker08
HTCC Member
djoker08's Avatar
The circled part is where it will not fit into the door panel
Old 04-05-2015, 08:36 AM   #4
justjoshin
justjoshin's Avatar
Is that a aftermarket insert? So is it too wide or too tall to fit?
Old 04-05-2015, 10:40 AM   #5
djoker08
HTCC Member
djoker08's Avatar
Yes they are aftermarket from RPI designs. On the factory one the hole at the end has a recess in it, this one does not. Shape wise it fit good
Old 04-07-2015, 06:33 AM   #6
BluePhoenix
BluePhoenix's Avatar
Drives: 23 Camaro 2SS 1LE
Did you line up the circle opening to the tab on the door panel to fit it through, just cover all your based on how it's supposed to mount.
2023 Camaro 2SS 1LE, A10, Summit White,
1100 - 3/23/2023
2000 - 3/27/2023
3000 - 3/28/2023
3000 - 4/04/2023 — 4/24 TPW
3400 - 4/12/2023 — 4/24 TPW
3800 - 4/28/2023 - Delayed ETA
VIN: 1G1FH1R73P0145237
5/10/2023 - ETA 5/27/2023
5000 - 5/30/2023
6000 - 6/3/2023
2024 GMC Sierra 1500
BluePhoenix is offline   Reply With Quote
