04-28-2015, 04:00 PM | #1 |
Drives: Camaro SS 2014 Join Date: Jan 2015
Matte Black Z28 Spoiler Installed
Finally, my z28 spoiler came in yesterday and I could not be any happier with it. Always wanted this Mod since I seen it on the z28 Camaro. The two holes I did not use, I put Aluminum Tape on top and bottom of them so water does not run down into my trunk. Did a 115 MPH Test today and that thing is secure and is not going anywhere
04-29-2015, 09:15 AM | #2 |
Drives: 2011 Camaro 2LT RS Join Date: Apr 2015
very sexy good job
04-30-2015, 07:25 AM | #3 |
Drives: 2014 1SS/RS Join Date: Apr 2015
Is that the OEM Z28 spoiler from GM or is that an aftermarket? Where are the holes you covered, can you see them after install? Looks great!
04-30-2015, 08:00 AM | #4 |
Lets roll...
Drives: 14' Join Date: Jun 2014
Looks good meng!
05-01-2015, 10:44 PM | #5 |
Drives: 2014 Camaro SS/RS Join Date: Mar 2015
Looks awesome. Did you have any issue with the paint under the spoiler?
05-01-2015, 10:47 PM | #6 |
05-01-2015, 10:49 PM | #7 |
Flying da helicopter
Looks great!
05-01-2015, 10:52 PM | #8 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
I have always liked white camaros with black accents!
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
05-02-2015, 12:34 AM | #9 |
Actually no, It looks exactly like the oem one though. Lines up perfectly with the body! There are 6 holes that the oem spoiler came with and drilled in my trunk. The aftermarket spoiler came with only 4 so i used the far left and far right ones and the 2 in the middle. The other two I used aluminum tape on top of the hole and at the bottom just incase water doesn't get in. Just washed it yesterday and not one drop got into my drunk. You can not see the tape cause the spoiler is over it.
05-02-2015, 12:37 AM | #10 |
I tried the blow dryer method to where you heat it up a bit and then pull it off but I still got a little paint taken off. Luckily, I bought some touch up paint from chevrolet a month ago and touched up some of the little spots that it got taken off.
05-02-2015, 12:38 AM | #11 |
05-02-2015, 01:27 AM | #12 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
Looks great did the same with mine.
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
05-13-2015, 04:42 PM | #13 |
Drives: 2014 camaro 2SS RS, Join Date: Mar 2014
did you get it from this website? http://www.spoilerandwingking.com/Ch...yle-SS-Spoiler
05-13-2015, 04:45 PM | #14 |
Sure did ))
