SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Technostalgia Taillights, who has fixed this before or knows what causes it?
Ok so everyone knows these lights are beautiful, and everyone knows these lights are the worst P.O.S. out there. Customer service? Doesn't exist. Warranty? Gotta change your lights
but I love them so I'm dealing with it. Right now the problem I'm having is that the left turn signals aren't working properly for the sequential function. The right side flashes inner, outer... inner outer. The left side is flashing both inner and outer at the same time (the LEDs are still sequential) I can upload a video later to show. I tried switching the resistor or ballast or whatever it's called and that didn't change anything so I don't think that's the problem, so I'm guessing it must be the little module inside with the switches on it for rapid fire brake/sequential turn signal. It seems to me that the outer left tail light is the problem, going off too soon instead of waiting like the right outer light does. Could be the inner left going off too soon as well I suppose, but it doesn't seem like it. Has anyone had this problem before? And if so what was the fix? If that's what's bad I can swap it out with my extra set of lights I bought for parts. |
Res Ipsa Loquitur
Drives: 2013 Camaro SS Vert Supercharged Join Date: Sep 2012
I feel your pain. I experienced the flickering of two of the lights when I first installed them. As of last night, half of the inner passenger light stopped lighting altogether and it wouldn't run the sequential pattern when the signal was on. Then, all the lights would run a sequential pattern randomly with the hazards on (I turned the rapid fire setting off so this shouldn't happen and only happens randomly). I checked the wires to make sure all was connected correctly and I discovered that the resistors (or whatever they are) were extremely hot. I'm not sure that that is normal. I took pics and video and I am waiting to hear back from them about what I should do next. I'm guessing the factory taillights will be reinstalled soon. Too bad, because as you said, I love these lights when they are working.
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
SHKE BKE
Yep I've had LEDs go out and lots of condensation issues that I've fixed, but this one is new.
And my resistors (or whatever) have always gotten hot when the lights are in use so I figure that's normal, so I assumed it may have burned out but after replacing it the problem was the same. I've left messages for them to call me back every day for a week or two now. Terrible service, hope nobody buys from them again. |
Res Ipsa Loquitur
Half working:
http://youtu.be/7gxBMJ-f-D8 Random sequencing while hazards are on: https://youtu.be/FMmo66TCfS4 Inner passenger light not sequencing: https://youtu.be/Nw11WXpOvOU
SHKE BKE
well I'm going to leave it disconnected for the reset procedure. I tested it with two other resistors just to be double sure (knew I was wasting my time)
Finally got a hold of someone and they said that resetting them may help, but my guess is that I'll have to replace the little module inside the outer left light. I took a video and I'll upload it later |
#6 | |
Res Ipsa Loquitur
#7 |
![]() Drives: 2011 Camaro Convertible 2SS RS Join Date: Dec 2010
After 3 + yrs I had my first issue that the error light came on the panel that the right rear bulb was out. I contacted Todd via email who responded and stated that it was the resistor. Within days i recvd a new resistor and that fixed the problem. Again after 3+ yrs this was the first issue and fixed very quickly at a minimal expense.
#8 | |||
SHKE BKE
also wanted to make sure my brakes and hazards were working so it's longer than it needed to be but here's the video. at the very end you can see all the lights except the outer right side go at the same time, which is why I think it's gotta be the outer left and not the inner left causing the problem.
#9 |
SHKE BKE
I left it disconnected again for a few hours, longer than last time, and it hasn't messed up since.
If it does again I'm assuming the computer/module inside the light will be to blame... |
#10 |
SHKE BKE
Well the problems back... and disconnecting it for about 18 hours did nothing to fix it this time so I'm guessing the computer inside the light is out.
Living with it until I have a chance to open it up and swap it with my other one that works |
#11 |
Res Ipsa Loquitur
Update on my situation. I sent Todd five emails before he finally responded. He apologized and asked if he could call me. I responded that he could certainly call me and I provided him with my number. To date, he has not called. Further, he is once again not responding to my emails. Annoying to say the least.
#12 |
![]() ![]() Drives: 16 Camaro SS Join Date: Jul 2012
Did you checked the DIP switches inside the lights? they're for Rapid Brake Light and Sequential Turn Signal. I'll bet the one with the problem has the switch set incorrectly. Make sure they are all at the same position.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
