Old 05-13-2015, 01:36 PM   #1
Buddy2
Buddy2's Avatar
Drives: 2012 camaro convertible 45th Ed.
Small Block
I have heard the L99 referred to as a small block engine. What defines an engine as small block vs. big block? Is it cubic inches, or the physical size of the block? What is the advantage of one over the other?
Thanks in advance for helping out a rookie.
CAI Intake, MagnaFlow Exhaust
Buddy2 is offline   Reply With Quote
Old 05-13-2015, 01:39 PM   #2
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
It's the bore spacing and other dimensions. 4.40 inches between bore centers for the small block and 4.84" for the big block. The big block also has a taller deck for longer stroke.
Small block is smaller and lighter. Big block allows for a larger cylinder bore which means more displacement.
Bhobbs is offline   Reply With Quote
Old 05-13-2015, 01:40 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I assume you know that there was a SBC and a BBC. Back then it was easy to differentiate one was bigger than the other.
The LS series shares some dimensions with the original SBC so that is why they sometimes get called a SBC.
In reality it's just a Chevy (GM) V8...
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 05-13-2015, 01:42 PM   #4
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Small Block 265 cid - 400 cid
Big Block 396 cid- 454 cid
In the old school days.
Quicksilver-SS is offline   Reply With Quote
Old 05-13-2015, 01:48 PM   #5
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
Kinda like the difference between a mouse and a rat.
SSeniorMoment is offline   Reply With Quote
Old 05-13-2015, 02:46 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Biggest small block I've heard of is a 472c.i. They're really pushing the limits of what the material that engines are built out of today.
Check out my build thread
Old 05-13-2015, 02:57 PM   #7
Mels RS
Mels RS's Avatar
Drives: 2015 2LT/RS Vert
Don't forget the big block 348 cid!
Mel
2015 2LT/RS 'Vert, RRM/Blk
Designated Airworthiness Inspector; specializing in Amateur-Built and Light-Sport Aircraft. USAF Vet.
<n168tx(at)flytx.net>
Mels RS is offline   Reply With Quote
Old 05-13-2015, 10:18 PM   #8
Buddy2
Buddy2's Avatar
I had a 348 back in the day. It was stuffed in a '57 Chey. I loved that thing till I blew a piston.
Funny how cars bring back memories.
Old 05-13-2015, 10:24 PM   #9
Firefighter
Wasn't the 348 a tall deck or something? I remember there being something odd about it.
Old 05-14-2015, 05:08 AM   #10
jimlem
Drives: 2013 Camaro 2SS RS 1LE
What about the Caddy 502 cu. in. (I think that's right). Used to be in all the ambulances built off the Caddy platform too, in the old days.
Edit: Sorry I just read your sentence again and saw you were discussing SMALL blocks. My bad.
jimlem is offline   Reply With Quote
Old 05-14-2015, 05:31 AM   #11
Firefighter
IIRC Caddy had a 472 and a 502. Those were different though. Chevy has a 502 but it is a GMPP part.
Old 05-14-2015, 06:47 AM   #12
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
yep.....it was called a W block code.....only two engines built with that specific configuration was the 348 and the 409. it was very obvious when you looked at them as the valve covers looked like upside down W's
Old 05-15-2015, 12:53 PM   #13
Buddy2
Buddy2's Avatar
Thanks guys. I always appreciate the help and information. I'm always learning something here.
Jim
Old 05-15-2015, 01:53 PM   #14
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Attachment 716232
You know what an upside down W is called??? M
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
