07-09-2015, 08:48 AM | #1 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
Tire Pressure
What tire pressure are you guys running on the street? Are you running a staggered set up, F/R? I had a G8 before this with 245/40/19 Pilot AS3's and the factory called for a staggered set up with the rears lower. I was running F38psi/R36psi cold to get even tire wear, OS edge still was chewed up from hard cornering in a heavy car. I am currently running Pilot AS3's at F39psi/R37psi hot. I have not been getting any wear on the OS edge with hard cornering, I am always getting the four wheel drift around certain corners and the edges/tires still look new. Just want to get the best handling/traction without giving up too much wear/ride.
07-09-2015, 11:19 AM | #2 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Tag on the inside of the door says cold tire pressure 32psi front and rear. I'm also running those pressures on my all-season street setup.
07-09-2015, 12:10 PM | #3 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I run (and the dealer does this too) 36 PSI cold on the fronts /34-36 rears on the street for better fuel mileage and wear (especially on the fronts). I have 285 PSS tires all around.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
07-09-2015, 12:41 PM | #4 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
We shoot for about 32 cold on all four corners. Climbs up to about 34 during operation. Seems to work well and getting about 15K out of the GY tires.
07-09-2015, 08:10 PM | #5 |
Okay, thanks guys. 32psi just seems so low with such a heavy car and a low sidewall. I guess I will will just start at 34psi cold and go down incrementally from there.
07-10-2015, 10:16 PM | #6 | |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
07-12-2015, 09:10 AM | #7 | |
BeckyD Rocks :-)
http://www.camaro5.com/forums/showth...=389234&page=3
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
07-12-2015, 11:21 AM | #8 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
32 cold as recommended on door. i've seen a 29 low parked and high of 37 when driven.
when i got my first oil change they were heated and the tech bozos started letting air out. i told the service manager and got the "eye roll". should've kept quiet lol.
07-14-2015, 07:47 AM | #9 |
Thanks everyone for the replies. I did read your post Kendall. It is nice to know I was somewhat correct on the tire pressure set up. Up here in WI the temps have been fluctuating like crazy, high or 87degs one day then a low of 52degs the next night. I think I will try the 36/34psi cold set up and see how that feels. That should give me a low hot temp of 38/36psi. These tires heat up very consistently at about 2psi under normal driving and 3psi when I drive aggressive.
07-14-2015, 08:56 AM | #10 | |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Air pressure is your rim protection. Not enough air pressure and the edge of a pothole will pinch your tire between the asphalt and the rim, cutting the tire and denting the rim. More air pressure also decreases rolling resistance, which leads to far improved tire wear, more consistent wear across the tread, and better fuel mileage. It lets the tire flex less which reduces tramlining (big one for me as the roads near me are absolutely atrocious). Yes, as I mentioned in the second sentence, you are giving up some grip, but we have so much with these 285-width G2s, that giving away some still puts us in the top tier of vehicles with regards to mechanical grip. I'm running between 38 and 40 PSI cold right now in the warmer months. In the cooler months, this pressure isn't enough to generate enough heat into the tires, so I lower it down to 36 PSI or so, and run different tires in truly cold winter stuff (once temps get below 40 degrees). There are a little over 13K miles on my G2s right now, and they are only about half worn. |
