getting old
Drives: 1993 Z/28 Join Date: Jul 2015
Air conditioning compressor works 50% of the time
Why does the A/C always go out when its hot outside?
The A/C worked last week. 2 days ago it didn't so I check and saw the compressor wasn't spinning. Today it is working normally. Low on refrigerant or is the compressor dying?
Joe
I must go to work.... there are people on welfare counting on me 1993 Camaro Z28, 2005 Suzuki GSXR 1000, 2011 YZ-250F, |
![]() Drives: 94 Camaro, 10 1LT IBM Camaro Join Date: Aug 2009
As the air temperature goes up it makes the A/C work harder, if the system is low on freon the compressor won't kick on. On a Cooler day the A/C may work but it probably has a freon leak. You might get buy for a while just adding freon but it depends if it is a slow leak or a faster leak.
getting old
Thanks.
Joe
