Old 05-05-2020, 01:21 PM   #519
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
All the fuel lines are ran/done
Throttle cable made
Got the fire system bottles mounted
Working on finishing the wiring, should be done today/tomorrow.
Bought a new laptop, one that is ssd that can take being in the car for a pass, the old one puked
Looking like it'll be started next week, as I've been dragging my feet working on it this week
12 camaro ss- sbe 6.0 TH400, GT5594-ETR, M1, 8.10 cert, backhalf, Ford 9", 32x14.5W tires, best ET 8.38@163.15
ttshovel is offline   Reply With Quote
Old 05-05-2020, 01:56 PM   #520
HOU_TX_SS
Drives: Camaro SS
What are you doing for brakes? Manual setup with proportioning valve?
416ci / Procharger F1X / Century Built 4L80 / Alky Control /Circle D Triple Disk / ID1300s / Fore Innovations Return / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
HOU_TX_SS is offline   Reply With Quote
Old 05-05-2020, 02:05 PM   #521
ttshovel
ttshovel's Avatar
Correct, its a dual master reverse swing setup
Old 05-05-2020, 08:04 PM   #522
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Looking good, would be cool to hear it if you decide to make a startup video!
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 05-06-2020, 07:44 PM   #523
ttshovel
ttshovel's Avatar
Got the bigger 1.40 a/r turbine housing today. This thing is huge in comparison to the 1.12
Picked up 2 drums of methanol($3 a gallon)
Got 90 % of the wiring done.
Started removing the motor plate to fix my water pump leak. Should be an easy/straightforward fix
Dropped my driveshaft of to be shortened as well.
Old 05-11-2020, 09:32 AM   #524
se7en
Drives: 10 Procharged SS
Oh yeah!!!
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
se7en is offline   Reply With Quote
Old 05-13-2020, 07:28 AM   #525
ttshovel
ttshovel's Avatar
Got the driveshaft in, 99% of the wiring done, got some more trans fluid. Went with a 20 weight hydraulic fluid this go round over the 40, since I was seeing .2% slip.
Couldn't find any fine thread 7/16 grade 8 bolts local for the converter, so I will be ordering those.
Attempted to start it, after troubleshooting, found there was no engagement of the front part of the cable hex. Using an aei cnc adapter, with motion raceworks cable. Ordered the motion adapter. Hoping that's the fix.
Sprayed starting fluid down the tb and it started right up.
Old 05-15-2020, 05:08 AM   #526
ttshovel
ttshovel's Avatar
Wired the backside of the egt bulkheads, just need to in them to the box.
Drilled and installed rivnuts for the trans dipstick mounting. Also filled the trans.
Converter bolts showed up, got those installed and bolted up. Took about 3/8" of spacer to get the right converter spacing.
Got the coolant system filled, no leaks.
Got the engine travel limiters made/installed.
Ran the wiring for the crankcase pressure sensor, fuel pressure sensor, and converter dump valve. Just need to solder the ends.
Motion cable adapter will be here today. Hoping that solves my fueling issue!
List is getting smaller by the day!
Old 05-16-2020, 09:42 PM   #527
ttshovel
ttshovel's Avatar
Took the pump off, pulled the bolts, spun it 180, reinstalled bolts and pump and thats all it took. Fired right up
Got the input expander to sync finally so I can start datalogging all my extras as well.
Old 05-17-2020, 12:10 AM   #528
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Let's get some videos!
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
BMR 1" lowering springs, trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified FULLY 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 05-17-2020, 06:44 AM   #529
ttshovel
ttshovel's Avatar
Not much but its something lol
Old 05-17-2020, 11:26 PM   #530
Tajefe Couple
Has to be a good feeling having it running again. Can't wait to see you get it dialed in. Incredible work!
Old Skool
Old 05-18-2020, 04:41 PM   #531
ttshovel
ttshovel's Avatar
Thanks man! It's been a long time coming for sure!
Spent the day plumbing the fire systems. Just need to make mounting tabs for 2 more nozzles and get the pull cables mounted. Which I ordered the m&m shifter mount bracket for.
My small list to finish- mount the dash, repaint the border on the windows, paint the wheelie bars, mount the coolant overflow, and finish the brake lines.
Still waiting on the front coilovers before I get an alignment on it
Old 05-20-2020, 08:14 PM   #532
ttshovel
ttshovel's Avatar
Made 2 tune revisions back and forth with the tuner. Now starts fairly decent.
Unfortunately I have a fuel pump shaft seal leak. Had quite the puddle of fuel under it.
Edit: pulled the pump off the car, pulled it apart, measured the shaft, and ordered the seal, and a new cover o-ring. Hopefully that takes care of the issue
Dropped my wheelie bars off at the local powdercoating shop to be done in black chrome. Stoked to see how they turn out!
Finally got a confirmation that my coilovers are built and will be shipped out Monday.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
