Old 09-20-2009, 04:41 PM   #1
BigFish
BigFish's Avatar
Drives: 1971 Z28
Cam installation
Hi all you camaro fans!
Is there anybody in the Indy surrounding area that has a cam installed in their new camaro...I have called several local speed shops and the highest so far was $10,000.00. The cheapest cost from the local GM dealer where I ordered the car from and it is $2200.00. I heard that people are saying it should not be over $800.00 anyone know of any places to get this done at a resonable price.
I have already bought the cam , valve springs and push rods just need them installed, with the car arrives in about 5 weeks.
BigFish is offline   Reply With Quote
Old 09-20-2009, 04:53 PM   #2
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
Cam install should be not a dollar over 1K, whoever told you 10K needs to have their business license pulled!
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
Old 09-20-2009, 04:59 PM   #3
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
$10K What the?
Old 09-20-2009, 05:20 PM   #4
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
Originally Posted by Andro View Post
$10K What the?
Gentry78 is offline   Reply With Quote
Old 09-20-2009, 05:38 PM   #5
BigFish
BigFish's Avatar
Drives: 1971 Z28
I heard ya...the 1st shop I called gave me the phone number for the second one and these idots just kept trying to argure with me over the phone, at 1st they said they would need to pull the motor out of the car to replace the valve springs. I told them the motor does not need to be pulled out to put in the cam and valved springs. I told them to remove the heads and there would be room to put in the cam. The guy on the phone said that he was the expert ...and if I didn't need his advice or help why was I calling. At this point a couple more thousand dollars I would buy me an LS9 motor. I can put cams in the old school cars...but with the new high tech cars....not just anyone can work on them (not me) .
As far as the GM dealer goes...they said $90.00 an hour @ 22 hours...I asked the manager does include an hour break after every hour working... I just don't believe it will take 22 hours to put a cam and springs in. maybe 8 to 10
Old 09-20-2009, 06:15 PM   #6
DTM
DTMphotography
DTM's Avatar
An experienced GM mechanic should be able to do a careful, clean job in about 15 solid hours, An LS1 expert should be able to do it in 8-10 solid hours
Old 09-20-2009, 06:16 PM   #7
DTM
DTMphotography
DTM's Avatar
and the LS3 does not need to be removed, you'll have a ton of extra space if you do but it's unnecessary
Old 09-20-2009, 07:43 PM   #8
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
I am pretty sure that the heads do not have to come off for a cam change.
rex113 is offline   Reply With Quote
Old 09-21-2009, 06:21 AM   #9
BigFish
BigFish's Avatar
Drives: 1971 Z28
I know the heads have to come off for new valve springs.
Old 09-21-2009, 09:34 AM   #10
maybelooking
Drives: 1990 mustang
my shop charges 65.00 per hour,
but we do so many cam installs we just do a flat rate of 400.00 (thats installing the cam and springs)
hell I could do the install, dyno tuning, and provide a custom grind cam, push rods, and springs for what you got install quotes for.
If you feel like a drive to Memphis, let me know.
901-461-2893
Jeff
we have a very good reputation over on LS1tech and we did a cam install on a camaro5 members car. do a search on Spectaclesolutions.
maybelooking is offline   Reply With Quote
Old 09-21-2009, 09:36 AM   #11
maybelooking
no they do not.
we use a neat little tool to put air into the cylinder and hold up the valves. Then we have another very nice little tool that allows us to change the springs on both valves in that cylinder at the same time.
Old 09-21-2009, 10:06 AM   #12
rex113
rex113's Avatar
Originally Posted by maybelooking View Post
no they do not.
Does the radiator have to be removed or tilted to slide the camshaft out?
Old 09-21-2009, 10:47 AM   #13
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Sorry BigFish but not true. They are done all the time with heads on engine. Motor stays in vehicle for cam swap as well. You do need to recover the refrigerant from HVAC system and then recharge after all is replaced along with the Dexcool in radiator. Radiator and condensor come out as well to provide room for cam removal. Oil change would be a good thing to do as well. Done in a day, easy!!
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 09-21-2009, 11:20 AM   #14
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
they think ur stupid
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a
3000, Order acc. by P.R---------- n/a
3100, Order available to sequence- n/a
3300, Order sch. for production--- 21may09
3400, Order broadcast------------ 28may09
3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199)
4000, Available to ship
4200, Shipped--------------------9june09
ITS HERE 18JUNE09
LSP2010 is offline   Reply With Quote
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Cam Vs. Cam Vs. Cam My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 12-11-2010 02:54 AM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 05:36 AM
cam installation kozzmo49 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 08-30-2009 05:42 PM
