01-09-2016, 12:55 PM | #1 |
Drives: 2013 White 1SS 1LE (? of 72) Join Date: Apr 2015
popping iut of gear
Two separate incidents, first time I shifted from 1st to 2nd low speed and when Iet the clutch out it violently popped out of second in to neutral. Second time was this morning, first gear let clutch out slowly and again the car violently popped out of gear again...??? Possibly not fully in gear? Or ??? Anyone else had this happen?
01-09-2016, 01:52 PM | #2 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
I would guess the shifter was not all the way in so when you let off the clutch and when it engaged it popped the shifter
01-09-2016, 05:59 PM | #3 |
Drives: 1LE Join Date: Feb 2013
This happened to be one time also, going from 1st to 2nd gear. I was trying to be too gingerly with a cold tranny, and I apparently didn't get it all the way engaged into second. At first, I was worried that there might be something wrong the transmission, but 1000 shifts later, it has never happened again.
01-09-2016, 06:12 PM | #4 |
Thats my thoughts also, that i wasnt fully seated in gear..... lets hope that its drivers error. Keep y9u all informed if it happens again
01-12-2016, 01:12 AM | #5 |
Drives: 2013 Camaro 2SS/1LE Join Date: Aug 2012
Mine has popped out on 1st and reverse a couple of times. I then noticed it wasn't in all the way. Sometimes it gets stuck half way through and I didn't notice it at first. Other times it won't even let me put it into first or reverse. I'm planning on going to the dealership but it's something I can't show them in person
01-12-2016, 04:20 AM | #6 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
You weren't all the way in gear. You need to keep your hand pressed on the shifter as you let off the clutch to ensure it stays/goes all the way into gear. That first little detent you feel is the syncros lining the gears up, but they are not yet fully engaged.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
01-12-2016, 05:11 AM | #7 |
BCS Auto
I know the Aisin Warner AY6 6-speed manual transmission for the LFX v6 includes troubleshooting procedures for weak/faulty detent springs/pins. If this keeps happening, and you know you were fully in gear, you might give your transmission service manual (found online) a look into.
01-12-2016, 10:37 AM | #8 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I've never had this happen. I've had where I could not engage 1st or R though.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
