Old 01-21-2016, 06:38 PM   #1
SSawdusty
Crewel Jewel
Drives: RJT-2SS-RS-6M
Help with Parts and Tuning Vendors Welcome
Here is a description of my car and its current mods as well as parts I already have and parts I wish to purchase. Just looking for a vendor that can give me a price as well as email tuning for this setup. Also looking for suggestions on what size SC pulley I can safely run after all is said and done.
Current setup:
2010 Camaro SS LS3 with Whipple SC with 3.875 pulley. MSD BAP. ZR1 MAP Sensor. ADM CAI & Scoop. Vmax Ported Throttle Body. Ceramic Coated LG Motorsports Super Pro Headers and Mufflers. Cat Delete.
Current parts on hand to install:
ID 850 injectors. ATI Super Damper with 6% Overdrive & 10 rib pulley system. DSS 1000hp driveshaft and axles.
Parts I'm wanting to purchase
Alky Control - Methanol Injection System - 2010-2015 Camaro - AK-10Cam-Kit. Single Nozzle, GM IAT Sensor Upgrade, AIS 4 Gallon Tank W/Retrofit.
BTR –PDS Stage III 3-Bolt Camshaft or similar specs
Trunnion Upgrade Kit
Valve Spring Kit
Pushrods
3-Bolt Cam Conversion
Timing Chain and Tensioner
ZL1/ADM Fuel module or LPE High output fuel system
Melling - High Pressure/Standard Volume Oil Pump - MEL-10295
As well all the gaskets and bolts required. I know most of this stuff come in a cam kit but you get the point.
Better suggestions are welcome too.
SSawdusty is offline   Reply With Quote
