03-17-2016, 10:44 PM | #1 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
Squash fuel system (fuel pressure sensor)
Are you guys keeping the stock fuel pressure sensor? The directions from Squash seem to delete it. Or are you going with aftermarket in the A pillar or just using the analog off of the regulator?
"J.Sick"
2010 Camaro 2SS |
03-17-2016, 11:12 PM | #2 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Many use something like this, don't have the exact one handy:
03-17-2016, 11:36 PM | #3 |
Drives: All things Turbocharged Join Date: Dec 2010
Unless someone has figured this out, the sensor can no longer be used once you go with aftermarket dual/triple pump assm.
03-17-2016, 11:58 PM | #4 |
Drives: ROCH-SS Join Date: Jan 2011
Damn i just bought a bunch of fitting to retrofitted on fore install. Wish i would known that.
03-18-2016, 12:06 AM | #5 |
Whats the reason it cant be use no more if you dont mind me asking?
03-18-2016, 05:38 AM | #6 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
it will work,but the FPCM will have to be connected and because the FPCM don't see the stock fuel pump anymore,it pops up the service engine light. I have my FPCM disconnected right now until I or someone figures it out to datalog or read it without the service engine light on.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
03-18-2016, 06:19 AM | #7 | |
Drives: Anything I want Join Date: Oct 2008
Lingenfelter has really nice Psi sending units,We have really nice small boost gauges that can also read fuel pressure ,just no datalogging. You could put a go pro on it during a run and go back and watch it.Or if you have a 5v input on you hp tuners cable or efilive cable or aeroforce gauge you could run it into one of those. Our display sits right below the tach,technically you could datalog it. |
03-18-2016, 04:24 PM | #8 |
If Andy didn't figured it out. I don't think nobody else can.
03-19-2016, 01:09 PM | #9 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Stock sensor moved to the rail for logging, after logging I pull the fuse to the FPCM and the code p023f goes a way, only put the fuse in for logging fuel pressure for my tuner, FPCM used to power and read the fuel pressure sensor only, works just fine.
03-19-2016, 01:13 PM | #10 |
Pretty much what I have seen, but have seen it done with the fitting like above so the wiring doesn't have to be moved.
03-19-2016, 01:40 PM | #11 |
That's 1 option
03-19-2016, 07:48 PM | #12 | |
Where is this fuse located? the fuse box in the trunk ? I don't have the car in front of me right now.
03-19-2016, 09:11 PM | #13 |
In the trunk behind the right side carpet
03-21-2016, 08:55 AM | #14 |
Drives: 2010 Camaro SS Join Date: Feb 2010
I have the Squash Fuel system. I put a pressure sensor on my fuel rail and use that signal to one of the analog inputs to my SCT device. I datalog through that.
Setting up the transfer formula was a PITA, but after that all is good.
LSX 429, Vortech V7 YSI, Squash Fuel system, Jannetty Tuned.
