Homepage Garage Wiki Register Social Groups Calendar Search Today's Posts Mark Forums Read
#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 03-20-2016, 11:34 PM   #1
Boxmonkey
Drives: 2015 STI
Tire Options
Has anyone tried to find a set of tire for the 1LE. There are not may choices. I think tire rack lists 2. I've even checked a few manufacturers sites. A lot make some for the front OR rear, but not both. Does anyone have any ideas on where to find more options?
Boxmonkey is offline   Reply With Quote
Old 03-21-2016, 07:55 AM   #2
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
285/30-20 there are 24 tires
305/30-20 21 tires
Pilot Super Sports are made for front and rear.
Not sure where you are looking?
thescreensavers is offline   Reply With Quote
Old 03-21-2016, 10:02 AM   #3
Boxmonkey
Drives: 2015 STI
Individually, yes there are that many options. There are not that many that match.
Old 03-21-2016, 10:34 AM   #4
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Match what?
Bhobbs is offline   Reply With Quote
Old 03-21-2016, 10:59 AM   #5
Boxmonkey
Drives: 2015 STI
Front and rear.
Tire rack does list several options but of those there are only 2 match front to rear.
If you look by size and choose the staggered fitment, only 2 options show up.
I have found those 2, plus the stock and maybe 1 or two others by searching manufacturers sites.
Old 03-21-2016, 11:07 AM   #6
Bhobbs
Bhobbs's Avatar
Front and rear.
The 6th gen 1LE has a staggered tire set up. The front is 285 and the rear is 205. The 5th gen had a square set up.
Old 03-21-2016, 11:26 AM   #7
Boxmonkey
Drives: 2015 STI
Correct. I'm just looking for a few more options for a staggered set up for a 6th gen 1LE where the front tires are the same type and compound as the rear. It seems there are only a few because of the sizes.
Old 03-21-2016, 11:43 AM   #8
thescreensavers
The goodyear tires do not exist yet either but they are coming with the 1LE and ZL1, so id bet we see some tire choices open up once the car gets released. Also there is a possibility of plus sizing to a more common tire size but seeing that these are 20s.. hah who knows.
Old 03-21-2016, 12:09 PM   #9
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
Originally Posted by Bhobbs View Post
The 6th gen 1LE has a staggered tire set up. The front is 285 and the rear is 305. The 5th gen had a square set up.
Fixed. 305 rear.
Problem is that 20" high tires are fairly new. It takes a while for companies to catch up to demand. Not much in the way for wide 19s either... it takes time.
I still remember when 17s were "tall" for a wheel. Now, they're VERY common, practically the normal size for a wheel dia.
--kC
Imp is offline   Reply With Quote
Old 03-21-2016, 12:10 PM   #10
Boxmonkey
Drives: 2015 STI
I hope you're right. I'm really looking forward to the car. It would be nice to have a few more options. I've heard good things about the goodyears that will be on it, but sometimes aftermarket does better and or cheaper.
Old 03-21-2016, 12:11 PM   #11
Imp
Imp's Avatar
Drives: Soon
Match what?
Same tire model that can be put on the front and rear of the car at the same time.
--kC
Old 03-21-2016, 12:13 PM   #12
Imp
Imp's Avatar
Drives: Soon
I can tell you that I will be ditching the OEM tires once Bridgestone has the RE71 or BFGoodrich has the Rival in a wide 19" or 20" dia.
--kC
Old 03-21-2016, 12:20 PM   #13
Boxmonkey
Drives: 2015 STI
I was hoping to see both of those, myself. Yokohama doesn't have a single tire that'll work with the stock 1LE wheels, yet. But I really like the RE71s I'm running on my Subaru.
Old 03-21-2016, 12:46 PM   #14
chetly
Drives: 2004 Z06
--kC
No plans as far as I know for 20in in those options. Bridgestone has the 285 in 19in and are planning on releasing a 305 in 19 as well. Rival has nothing larger than 18in planned...
chetly is offline   Reply With Quote
