03-24-2016, 04:12 PM | #1 |
Camaro addict
Door speaker component sets
Found some new 'old stock' of BA PRO 60SE compoents on ebay. Everywhere I go seems these are pretty awesome. Anyone have a set?
http://www.ebay.com/itm/-/182065984049?
2014 SS2 A6 Loaded - Procharger i1 - ZL1 pump - ADM FPCM - ID850's - HPTuners Tuned - Kooks LT - ALKY System - Cunningham installed - 565/565 RWHP/TQ @ 8.5psi
03-26-2016, 03:10 PM | #2 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
I've had several sets of Boston Pro's in my vehicles over the years, they are awesome. I have won several SQ competitions over the years using Boston Pro's, when I used to work in car stereo. That is also the best price I have ever seen on a new set.
03-26-2016, 04:06 PM | #3 |
Camaro addict
thanks! purchased
03-26-2016, 04:16 PM | #4 |
SS
are these a direct swap with premium BA stock speakers or is some expertise required?
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
03-26-2016, 04:21 PM | #5 |
Camaro addict
there is a cheap kit from crutchfield I just bought for the swap. otherwise you can grind on the factory mount.. tweeters go in the factory spot from what i read, crutchfield sends a PDF about how to take the door panel off and so forth....
http://www.crutchfield.com/p_142SMH6...-Brackets.html that and for fun I am doing the amp FARK kit from ******** also, but not needed
03-27-2016, 02:14 PM | #6 |
I run 2 catch cans...
This is about the only advantage when a mobile device manufacturer decides to leave the market. I picked up my G3 subwoofer and both amps at a big discount.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
Thread Tools | |
