Old 03-29-2016, 12:00 AM   #1
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
Could I use this wire for a 5V for my fuel pressure sensor?
I installed the squash fuel system and have removed my FPCM. I still would like to datalog fuel pressure without buying an aftermarket gauge setup. I am thinking of moving my stock fuel pressure sensor to the engine bay and using pin 50 (see attached) to power the sensor since I don't need to power the FPCM anymore. Then I will run the signal wire to my HPTuners and datalog fuel pressure. Does this sound like a working plan? Am I missing anything?
Thanks,
Joshua
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 03-30-2016, 10:10 PM   #2
jasycz28
J.Sick
jasycz28's Avatar
I changed the question.
"J.Sick"
2010 Camaro 2SS
Old 03-31-2016, 06:06 PM   #3
stevieturbo
Drives: it changes
Pin 50 is listed as fuel pump relay control. That is in no shape or form a 5v feed.
If you wanted a 5v feed....there would be a clue in all those items listed as "5v reference feed"
Although I'd prefer something that isnt dedicated to a pedal position sensor at the same time.
All sensors generally require a sensor ground too, not a chassis ground.
ie those marked "low reference" on that chart.
Although as you're only recording it and not using it for any actual controls...probably not a big deal either way.
stevieturbo is offline   Reply With Quote
Old 04-01-2016, 12:56 AM   #4
jasycz28
J.Sick
jasycz28's Avatar
I think I am just going to buy an aeroforce sensor with the 5V regulator.
"J.Sick"
2010 Camaro 2SS
