Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Motorsports Discussions
Old 04-02-2016, 09:18 PM   #1
hebronchief@yahoo.com
Drives: 2010 camaro zl427
stock bottom end
how good is a l99 bottom end. I have a whipple pushing 12 psi with 50 shot of nitro with methane injection. dyno 740 flywheel with auto trans breaking down to 626 to the wheel. does anyone know what the max maybe???
hebronchief@yahoo.com is offline   Reply With Quote
Old 04-04-2016, 09:12 PM   #2
catlettZL1
catlettZL1's Avatar
Drives: 2013 White ZL1 coupe 682hp/672tq
With a good tune your probably there right now
catlettZL1 is offline   Reply With Quote
Old 04-05-2016, 04:23 PM   #3
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
The L99 bottom end is just as strong as an LS3 bottom end. Several boosted applications making 700-900+ to the wheels on the stock bottom end and holding up just fine over time (meaning they didn't do just two pulls on the dyno and then put in a safer tune after). Personally I think 750 is the most I'd want to play with, but it's up to you if you want to put your engine to the test. You should have no issues whatsoever at your current level if it's set up and tuned well.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 04-11-2016, 11:31 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
It should hold stock, but a safe bet would be ARP studs for the main caps over the OEM bolts, and ARP head bolts. Cheap insurance. I'd say your getting close to numbers that would warrant forged rods.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-12-2016, 03:56 PM   #5
Hard Parker
Hard Parker's Avatar
Drives: ZL1
bottom end will hold more than your trans will
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 04-12-2016, 04:16 PM   #6
rvadim76
Drives: SOLD: 2012 Chevy Camaro 2SS
That's exactly what I was going to tell ))
2OP: I think for the A6 tranny you're very close to hit the limit!
rvadim76 is offline   Reply With Quote
Old 04-12-2016, 09:40 PM   #7
Jacokyla
Jacokyla's Avatar
Drives: 2011 SS Super Charged 636RWHP Meth
Trans is issue. I am at 636 wrhp just had trans rebuilt.
Jacokyla is offline   Reply With Quote
