04-06-2016, 07:44 PM | #1 |
RPI Designs 2016 Camaro SS Stainless Works Axle Back System Dual Tips(Performance)
2016 Camaro SS Stainless Works Axle Back Exhaust System Dual Tips
(Performance Connection) The Best In Performance & Sound Choose the Factory Connect option to fit to the factory break-point, or get the most out of your Camaro with our Performance Connect option which fits to our headers and maintains a full 3" system without necking down. Our tailpipes include a valve delete plate that allows you to mount the electric motor and alleviate any AFM engine codes on the dash. It's an easy 3 bolts to install. Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers Features: ‣ 3" diameter system ‣ Aggressive exhaust growl ‣ Mirror-polished tips ‣ 304 stainless steel construction ‣ TIG welded for strength ‣ Mandrel bent (no buckling) for optimal flow ‣ Design and Made in Chagrin Falls, Ohio, USA Performance and Sound Proudly Made in the USA Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship. Item # CA16MKS-PC Website Link : http://www.rpidesigns.com/shop/item....ce-connection/ |
11-18-2017, 09:37 AM | #2 |
07-08-2020, 07:15 AM | #3 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
2016-2018 Camaro SS Stainless Works Axle-Back Exhaust System Dual Tips
(Performance Connection) Item # CA16MKS-PC Website Link : http://www.rpidesigns.com/shop/item....ce-connection/ |
