04-14-2016, 02:44 PM | #1 |
Rubber lower deflector part number
Does the rubber lower deflector have is own part number or is it attached to the front lower bumper assembly? Mine has come off and the dealer doesn't know what I'm talking about.
04-14-2016, 03:06 PM | #2 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Your talking about the Front Splitter at $400.00 and it comes with the fasteners.
OLD GUY FLYING FAST AND LOW
04-14-2016, 03:36 PM | #3 |
No it isn't the splitter it's the deflector that is mounted under and just slightly behind the splitter. Unless you mean to say that piece comes with the splitter. From what I have seen though on GM Part store pictures it does not.
04-14-2016, 04:26 PM | #4 |
Drives: 2015 2SS/RS 1LE G7C, Join Date: Nov 2015
The air deflector is separate and comes in a vacuum pack bag, I changed mine out over the winter. GM part # 22829564 online around $50 bucks.
04-16-2016, 09:55 PM | #5 |
Did you swap it out yourself? How easy was it to do? My dealer is retarded and cant even find the part number. Even after giving them the one you posted they are still arguing that it doesn't belong on my 2014 1LE. I'm finding that most dealers (service department) know little to nothing about 1LE's. Every time I take mine in I basically have to explain/argue something to them.
04-17-2016, 01:47 AM | #6 | |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
"Make yourself sheep and the wolves will eat you"
04-17-2016, 08:02 AM | #7 |
Not difficult without a lift, I got it done laying on the garage floor (with a lift a 15-20 minute swap out) you just need to get at all of the retainers and it is the correct part#. Then go order one from www.iamgmparts.com it's $48 there. The retainers are NOT the pushpin style (at least on my 15). Go take a look from under the spoiler, you should see flat head screwdriver type heads. Their are 14 black plastic nut & bolt style fasteners attached along the length of the rubber deflector. So on some of them you will need to use a wrench to hold the nut while turning out the bolt until you can hand unwind it the rest of the way. The front 10 were easy access, I removed the 2 metal screws in the wheel well liner to better access the 2 bolt heads on each end. Start again at both ends when installing the replacement deflector and work your way back to the center of the nose. That's it.
04-17-2016, 11:35 AM | #8 |
Thanks for clarifying. It's been a long time since I did it on my old '12, but I remember it was an easy process
04-17-2016, 01:47 PM | #9 |
thanks for the clarification. Mine has been completely removed by a road hazard of some kind So just have to reinstall the new one thanks again for the part number as well.
