Old 04-20-2016, 11:03 AM   #1
Misterxman
Misterxman's Avatar
Drives: 2014 2SS/RS RRM
Can anyone help me with these dash error messages?
I started my car this morning to all this! Nothing new has been done to the car since a muffler delete over a month ago. Please help me out if you know what's going on or have suggestions. Thanks Don.
CAI Intake, Spoiler Kings Z/28 Spoiler, VTC,
Misterxman is offline   Reply With Quote
Old 04-20-2016, 11:06 AM   #2
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
Do you have an OBDII scanner? Pulling the codes would be step 1.
HyperV117 is offline   Reply With Quote
Old 04-20-2016, 11:07 AM   #3
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Did anything unusual happen the last time you drove it? Try disconnecting the battery, let sit for 5-10 minutes before reconnecting & see if it goes away.
Old 04-20-2016, 11:11 AM   #4
Misterxman
Misterxman's Avatar
No scanner and I drove home from work last night and everything was just fine. I will try disconnecting the battery. Thanks.
Old 04-20-2016, 12:06 PM   #5
Misterxman
Misterxman's Avatar
Disconnected the battery and everything went away I hope for good. Thanks for the suggestion. Any idea why everything just popped up? I am all about fixing something but I don't want to just put a Band-Aid on something if something else is wrong or if it will go wrong down the line if it can be prevented ahead of time.
Old 04-20-2016, 02:48 PM   #6
Firebreed
Got Boost?
Firebreed's Avatar
Drives: 2011 1SS/RS M6 SLP TVS 2300
Hard to say without the codes
sent from the middle of nowhere, Pacific ocean
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs
CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers.
Future Mods: 416ci stroker.
Firebreed is offline   Reply With Quote
Old 04-20-2016, 04:01 PM   #7
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
Code readers are cheap and useful.
If anything continues to be a problem, the errors will reappear.
Good luck!
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 04-20-2016, 04:38 PM   #8
ocautomotive
Drives: 2017 ZL1 and 2018 SS 1LE
That happened to my 2014 and i went to disconnect the battery and the lead was super loose.
ocautomotive is offline   Reply With Quote
Old 04-20-2016, 05:18 PM   #9
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Good luck!
^^^This and you can go by an auto parts store, like Autozone, and they can pull the codes also.
Old 04-20-2016, 05:22 PM   #10
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
It will likely come back. Shitty throttle body electronics.
maddoggyusa is offline   Reply With Quote
Old 04-20-2016, 05:39 PM   #11
Misterxman
Misterxman's Avatar
If I went to said auto parts store would they still be able to read the last error codes or since I disconnected the battery are they now cleared out? Thanks
Old 04-20-2016, 05:45 PM   #12
Ragnar
Ragnar's Avatar
Drives: Wife's car
Since you disconnected the battery, then no. That erases codes. Now the car is starting to rerun all of it's tests. If something is not right, the light will come back on.
Old 04-20-2016, 05:49 PM   #13
Misterxman
Misterxman's Avatar
How long should it take to come back on if it is going to come back on? I disconnected the battery and all was good I then drove for about 20 minutes and no error codes so am I good?
Old 04-20-2016, 05:53 PM   #14
Welker2
Welker2's Avatar
No telling how long; it could have been a one time cliché (doubtful, but possible) or random, may happen again within the next few miles or it may take months. If and when it happens again, run down to your local parts store & have them check the codes before clearing them/disconnecting the battery. Good luck
