Old 04-21-2016, 10:32 AM   #1
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
OEM Tunnel Brace
I saw posts regarding aftermarket parts, but didn't see anything regarding the OEM part(s).
Do the convertibles have an OEM tunnel brace like the coupes?
If so, is the part identical?
PDXSSCE is offline   Reply With Quote
Old 04-22-2016, 02:30 PM   #2
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Someone?
Old 04-22-2016, 03:12 PM   #3
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
My guess is it would be the same, here is a link to an aftermarket one that lists for all models
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 04-22-2016, 03:16 PM   #4
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
The verts have additional bracing like that compared to the coupes. Some interfere with mid-pipe upgrades to 3". Why do you ask?
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 04-22-2016, 03:33 PM   #5
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I ask because of the following thread:
http://www.camaro5.com/forums/showthread.php?t=447758
I'm wondering if it's something my car could use & if so would it fit?
Old 04-22-2016, 03:39 PM   #6
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
The coupe and vert brace are identical. the vert has a second brace with 8 mounting holes further towards the front of the car. Any tunnel brace fits either chassis.
2012LS3VERT is offline   Reply With Quote
Old 04-22-2016, 03:40 PM   #7
Indydriver
Nice stout piece. I wonder if you could feel the difference. Here's the ARH brace I considered in order to add their 3" midpipe but the hp/$ equation wasn't attractive. This "chromoly" tubing brace with multiple anchor points should be an improvement over the OE stamped steel.
Old 04-22-2016, 03:45 PM   #8
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Thank you!
You've all been very helpful.
Old 04-22-2016, 04:19 PM   #9
2012LS3VERT
The ARH brace pictured is a nice piece, it would replace both braces on the vert, the coupe has the holes for the front vert tunnel brace, which the ARH brace uses. The difference, however, is negligible. Most won't feel a difference in chassis stiffness. The tunnel braces under the car from the OEM are to resist collapse during a side impact. These cars are very stiff from the factory, the only reason to add bracing is using R-compound rubber in a track setting. The vert only requires additional bracing because there is no roof structure to resist flexing under load.
Old 04-22-2016, 04:24 PM   #10
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
What's your thought of the OEM brace pictures in the OP?
Old 04-22-2016, 06:20 PM   #11
2012LS3VERT
It does what it is supposed to do, which is resist forces that would let the trans tunnel collapse in a side collision. You car has one stock, so i'm not sure what you are needing to know?
Old 04-22-2016, 08:45 PM   #12
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I guess the more direct question, is if there's something to be gained in handling by replacing it with a sturdier one?
Old 04-23-2016, 04:41 AM   #13
2012LS3VERT
Nothing that you will notice unless you are running race tires. I've tried several different designs on mine. The car doesn't flex in that direction, and the mount points are too lose together to stiffen anything other than the small section of trans tunnel.
Old 04-23-2016, 07:09 AM   #14
Indydriver
But, the guy fabbing them is only asking $15 to cover his shipping cost. So.....
Given your interest, why not get one, try it out, and give us a review?
