Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-24-2016, 05:53 AM   #1
marklt
Drives: 1995 Camaro Z28
th350 issues
Hey all, thoughts on what might be going on......75 lt350 / th350. trans has had sloppy shifts from 1st to 2nd and 2nd to 3rd (but not quite as bad) for the 3 years since have owned it. its worse when cold. can still pull well under WOT. engine brakes if manually down shifted. Fluid ok, been serviced. last service report noted the poor (slip change), rebuild?
marklt is offline   Reply With Quote
Old 04-25-2016, 10:34 AM   #2
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
You may can have a trans shift kit added to improve the shifting. Not sure of the miles that you have, but I would consider having the transmission rebuilt. Then you will be set for years to come. I always hated a crappy shifting car. Good luck!
