04-29-2016, 02:21 PM | #1 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2009
BMR Suspension's 6th Gen IRS Cradle Bushing Lockout Kit - Pics, Vid and Info!
We are finally starting to get some parts made up and shipped out. After testing, revising and testing more we are on to a good start with this platform!
One of my favorite products, and one I suspect will be our "homerun" part, is our IRS Cradle Bushing Lockout Kit. BMR has been providing aftermarket IRS solutions for over 10 years now, and we like to think we are evolving as much or more than the amazing vehicles that these Auto Manufacturers are providing us with. Traditionally, removing deflection and sloppy performance of the IRS has been accomplished by removing the cradle from the vehicle and replacing all of the rubber pivot and mounting points with more rigid materials such as Polyurethane, Delrin or Aluminum. While these solutions work, and work WELL - these newer more refined vehicles tend to perform quite well with that deflection in place. As the OEM's improve their engineering and offerings to the consumer, we try and ensure that we follow suite. Enter our IRS Cradle Bushing Lockout Kits. For the 6th Gen Camaro, we have finalized our design to include a number of uniquely designed components made from Delrin, Aluminum and Stainless Steel. These components are the highest of quality, and as you will see in the video below, remove a tremendous amount of Cradle Deflection (without increasing NVH much at all) Here is a shot of the 2016+ Camaro IRS Cradle, from front to back A shot of the BMR Cradle Bushing Lockout Kit We designed this kit to reduce fore, aft, vertical cradle movement/deflection....as well as align the cradle to the chassis better than how it comes from the factory (which leads to better IRS suspension geometry) Starting with the front upper bushing, we put a centering spacer in the OEM sleeve that centers the bushing to the OEM 3/4" lug. Factory Upper Side Front Bushing Spacer Installed Delrin Upper Lockout Ring, Fills the Void and Reduces Vertical Movement by increasing the rubber durometer/stiffnes Flip to the bottom side of the front bushing, and check out those voids! Here I show the lower bushing lockout ring, and it's intricate machining to fill the voids Massive Stainless Steel Washer to provide the proper clamping load to make the front system work as designed, and protect the Delrin Lower Ring from being damaged. On to the rear. Here is a shot of the OEM Upper Rear Bushing Mount Upper Delrin Lockout ring, to fill voids and minimize deflection On the bottom side, take a look at the sloppy rear bushing and massive voids. Enter, our unique aluminum "Bullets" to fill those large voids- these things are pretty cool! And here you see our aluminum washer, designed to hold the Bullets in place as well as limit the cradle movement by locking the edge of the cradle to the center OEM Sleeve. Finally, here is a teaser of some of the deflection that is removed from this easy bolt-in kit. If you have any questions, this is the thread to ask! |
04-29-2016, 02:33 PM | #2 |
Nightfall Gray Blackout
Drives: 2016 Camaro 2SS Join Date: May 2012
Any shop that you recommend here in Long Island New York?
04-29-2016, 02:52 PM | #3 |
Drives: 2016 Camaro SS NPP Join Date: Mar 2016
You guys need to release the lowering springs already.
2016 Camaro SS - Nightfall Grey
1999 Camaro SS - Torch Red 1995 Camaro RS - Torch Red |
04-29-2016, 03:31 PM | #4 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
04-29-2016, 04:04 PM | #5 |
No body wants that more than we do! Me specifically....lol.
Coming, they're coming! |
04-30-2016, 12:38 AM | #6 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
So what percentage of the deflection is removed with this setup? I take it a full bushing is in the works maybe?
And can that cradle just be dropped a bit, side by side like installing inserts on the 5th gen?
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
04-30-2016, 12:58 AM | #7 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Love all this crazy awesome stuff you are designing for the Gen 6....but I think 75% off us will not buy this type of product.
We will buy your springs and sways though! Get on it! What would be the labour to install this? How many hours will be booked by our mechanic? 4? 8? Will this cost $500 to install. SP044 Please. I'm First in Line!!
04-30-2016, 11:34 AM | #8 |
Drives: 2016 2SS Join Date: Feb 2016
This may be a stupid question, but does the entire rear subframe need to be removed to install this?
04-30-2016, 02:15 PM | #9 | |
Drives: 1999 SS Join Date: Jul 2009
suspended
Can you pm me on that gen 4 kit ? Thanks Victor |
05-01-2016, 12:24 AM | #10 |
Drives: 15 Silverado, 15 Corvette 2LT Z51 Join Date: Aug 2012
How much of a wait are we looking at for the release of the lock out kit?
2016 Camaro 2SS Mosiac Black Aka-The Reaper
Build Thread- http://www.camaro6.com/forums/showthread.php?t=440437 |
05-01-2016, 03:37 PM | #11 | ||
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I'm kind of wondering why GM made these bushings so complex but I like that you guys at BMR just tighten up the existing material rather than throw it all away and slide in something else. Looks like a great product! I'm sure a set of those are going to end up in my car before too long!
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
05-02-2016, 06:55 AM | #12 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
It appears you could loosen all 4 bolts, then drop a side at a time to install these very easily. Can you confirm that?
Does the rear suspension/body ride height increase due to the additional height of the insert flanges above the subframe? How much is NVH affected? My car sounds like a monster truck on mudders already on rough Texas roads. MRC Springs!!! |
05-02-2016, 10:52 AM | #13 | |||||||
Off the top of my head, I cannot think of any shops we recommend there. Sorry.
Yes, full bushings are en route. This kit will work "about" as well as a Poly Bushing system. Yes, the cradle can just be dropped (lowered) a little to install this kit. Quote:
This kit is not specifically designed for racing, or drag racing, or to remove wheel hop. It is designed to make the car more enjoyable in every way - handling, braking, cornering, etc. I think many people who may initially say "meh, thats not for me" - will end up acquiring these BK063 Kits. Labor wise, I cant see it being more than 2-3 hours. SP044 - FTW!!! Quote:
kyle@bmrsuspension.com Quote:
I think this will be up towards the top as one of our best sellers for the 2016+ 6th Gen Camaros. Quote:
Ride Height is not affected. The heights seen in the pics are not a representation of how the parts look once installed. The rubber compresses and the oem Sleeve sits flush and contacts the chassis, as it does in stock form. NVH is not increased much at all. Honestly, I can't even tell this part is on the car NVH-wise. |
04-07-2019, 06:11 PM | #14 | |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I know this is a very old thread, but are you saying the poly bushings are better than these? And how does this affect a MRC suspension if it does? Also is installation straight forward, or are there other certain items that need to be removed for installation. Keep in mind, I haven't been under my car yet, so this one may be a dumb question.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
