05-06-2016, 04:15 PM | #1 |
Drives: 2009 Corvette Z06 Join Date: Aug 2009
Now available from SCP: 6th Gen Camaro SS Momentum GT Pro Stage-2 Intake
2016 6th Generation Camaro SS Momentum GT Pro Stage-2 Intake System
Unique One-Piece High Quality Housing W/ Sight Window: A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air scoop. High Quality Tube: This system uses a high quality plastic CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. Also included is a high quality billet aluminum crankcase fitting provided for easy installation. This tube has a built-in resonance chamber to catch un-wanted air intake noises. High Quality Scoop: A high quality CAD air scoop guides cool ambient air to the performance air filter. Large 3-Layer Performance Air Filter: This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cylindrical filter has a large oval (6-3/4" x 4-3/4") flange and is 9" tall inverted top Pro DRY S filter media. The Pro DRY S performance air filter features 3-layers of progressive finer porosity synthetic media providing maximum convenience with 100% polyurethane frame for long life and multiple cleaning cycles. Premium Hardware: Premium stainless steel T-bolt clamps and a reinforced silicone elbow coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation. Note: This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles. Features: Performance Data Coming Soon! High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Scoop CAD-Designed Roto-Molded Intake Tube w/ Resonance Chamber Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly Scoop snaps into air box and directs cool air into intake system for maximum performance and hassle-free installation Pro 5R pre-oiled, washable/reusable air filter for maximum performance Pro Dry S Oil-Free washable/reusable Filter For Maximum Convenience• Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation No Cutting or Drilling on OEM Parts for Faster Installation Click here to order: 2016 6th Generation Camaro SS Momentum GT Pro Stage-2 Intake System |
07-06-2016, 10:53 AM | #2 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
No claims on performance gains for this intake?
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
03-30-2019, 08:22 AM | #3 |
11-04-2022, 06:26 AM | #4 |
Because these items are custom painted to order we do ask for additional time to ship your order.
Order here: 2016-2017 Camaro Gen 6 Custom Painted Underhood Accessories Package |
01-16-2023, 10:48 PM | #5 |
Thank You for shopping at https://www.southerncarparts.com/201...ge-p-9184.html
