Old 05-15-2016, 01:27 AM   #1
camarogen156
Drives: charcoal greay ss
someone help please lots of oil in coolant turbonetics ss
Ok so I have a 2010 camaro with a turbonetics 50 state kit. Car ran great but the other day I noticed a small radiator leak coming from one of the hoses that had a small slit in it. No big deal easy fix. So I go about fixing it and open up the rad cap and see peanut butter in my coolant and a lot of it. Obviously oil. So my question is could the turbo be mixing the two because it has oil and coolant feed or head gasket? Car never over heated ran at 190 all the time.
Please help!!!
camarogen156 is offline   Reply With Quote
Old 05-15-2016, 04:49 AM   #2
bayarea408
bayarea408's Avatar
Drives: T
If your turbo is coolant and oil cooled that could be the culprit. Definitely what I would test and check first.
Secondly it could be a head gasket.
Are you on stock gasket and head bolts? How much power and how many pounds are you pushing.
In really bad scenarios you could crack a head, but I would deem that unlikely.
bayarea408 is offline   Reply With Quote
Old 05-15-2016, 05:57 AM   #3
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
^^^^^ + 1
JD_Alaska is offline   Reply With Quote
Old 05-15-2016, 07:55 AM   #4
Unreal
Drives: 2006 Z06
No way it is mixing in the turbo. Just not going to happen.
You lost a head gasket, or cracked the block.
Nick
Corvette Z06 -1200ish rwhp
Old 05-15-2016, 08:33 AM   #5
jrhagen
Banned
Drives: Camaro
Head gasket or worse.
jrhagen is offline   Reply With Quote
Old 05-15-2016, 09:34 AM   #6
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Doesn't look pinkish but could be the trans cooler in the radiator that took a shit
DarkCry956 is offline   Reply With Quote
Old 05-15-2016, 11:03 AM   #7
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Whats the dip stick look like?
Nitroman28 is offline   Reply With Quote
Old 05-15-2016, 01:22 PM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Originally Posted by Nitroman28 View Post
What the dip stick look like?
+1
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-15-2016, 02:59 PM   #9
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
How about doing a pressure test on the radiator?
ttshovel is offline   Reply With Quote
