Old 05-28-2016, 09:39 PM   #1
Grote
Drives: 2013 2SSRS Drop Top Sick Speed
Boot Cover - Tab broken
Just had one of the rubber tabs at the front of my factory boot cover break off. Luckily I found it in the well by the rear side window.
Has anyone else had this issue?
Thanks
Grote
Grote is offline   Reply With Quote
Old 05-29-2016, 08:19 AM   #2
c-57d
Drives: 14 2SS/RS Triple Black Ragtop LS3
Hey Grote,
I haven't had that happen but I'm interested in this.
If you could post a pic I'd like to see where the piece broke off.
c57-d
Come see the violence inherent in the sysadmin.
c-57d is offline   Reply With Quote
Old 05-29-2016, 08:47 AM   #3
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
which boot?
what well?
sorry, I got nothing.
FunkedOut is offline   Reply With Quote
Old 06-27-2016, 03:49 PM   #4
Grote
Boot Cover Tab Broken - additional
See pictures - (note I had added the sound mat to help reduce noise)
One picture shows tab the other shows with my repair.
More importantly:
I have changed the way I install and remove the cover. When installing I used to install the back of the cover before bending the front tab down and inserting. When removing I would pull up the front of the cover bending the tab. Once a tab broke I now put tab in before the back edge on installs and remove the back edge and slide the cover towards back so tab does not have to flex.
Old 06-28-2016, 08:50 AM   #5
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
Thanks
Grote
He means the plastic "tongue" (tabs) that protrude from the front ends of the tonneau cover which tuck under the plastic trim pieces next to the rear side windows which anchor the front of the tonneau to the car.
I'm always a bit concerned that I might break one of those tabs if I were in a rush to put the tonneau on or take it off.
How did the fix go? Does it hold well? Damn tonneau covers are expensive to replace!
Summit White
Black Leather
3 Pedals
Build Date: 06/27/2011
Purchased: 07/30/2011
Title Received: 08/15/2011
1984 Camaro (3rd Gen.): Traded: 1987
"Meet the new boss. Same as the old boss."
Baba is offline   Reply With Quote
Old 08-29-2016, 10:14 PM   #6
Mr.T1982
Mr.T1982's Avatar
Drives: 2013 Camaro ZL1
Grote - if you are still under warranty have it replaced. I had the same thing happen and just got a brand new given to me
2013 Camaro ZL1
800HP
Mr.T1982 is offline   Reply With Quote
Old 08-30-2016, 08:41 AM   #7
Grote
The repair is holding up well, as I had posted earlier by changing the way I install the cover there is less stress on this tab. I am pretty sure because of the sound mat I installed my warranty would be voided.
Old 08-30-2016, 11:26 AM   #8
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
I just used mine this weekend for the first time. I really did not like how I had to bend those tabs to get it to slip underneath. Maybe I was installing it incorrectly??? Once it was on, it did seem very sturdy and would not fly off while driving.
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 08-31-2016, 06:16 AM   #9
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
More importantly:
That is how I have always installed mine, it puts practically no stress on the front tab when putting on or taking off.
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
