Old 05-31-2016, 11:17 AM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
New pb but not what I was expecting
Well I recently took my new 2010 l99 to the track. Car has SLP tvs2300, custom comp cam, lt headers, corsa catback, cai, ported TB, 3.45 gears with true trac. Car was dyno'd at 613 whp at 13 psi boost on the 6l80. Car now has th400 with a tci 3200 converter and I haven't dyno'd it after the swap. New pb because I'm coming from a ls3 na to a sc l99 but was not satisfied at all. Can anyone guess what's wrong?
First run
https://m.youtube.com/watch?v=OvRB02wMVuo
Second run
https://m.youtube.com/watch?v=y-EVZ7X6KCI
camarosspower is offline   Reply With Quote
Old 05-31-2016, 12:40 PM   #2
pancherj
Drives: 2010 Camaro SS
What did the whole slip look like on that second pass? 3.45 gears and TH400 isn't a great combination for launching a heavy car. Also, what RPM was it shifting gears at?
pancherj is offline   Reply With Quote
Old 05-31-2016, 01:16 PM   #3
camarosspower
First run
Old 05-31-2016, 01:18 PM   #4
camarosspower
2nd run.
Old 05-31-2016, 01:22 PM   #5
camarosspower
I think it launched pretty good at 3k rpm on the 2nd run. Transmission was shifting at around 5k rpm. On the first run I never let off the throttle even though it seems like i did.
Old 05-31-2016, 01:58 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Shifting at 5K is way too low.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-31-2016, 02:07 PM   #7
jrhagen
Banned
Drives: Camaro
This
jrhagen is offline   Reply With Quote
Old 05-31-2016, 02:30 PM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
5k yeah that's waaaaaay too soon to shift. You need to dial that thing in
62nalide is offline   Reply With Quote
Old 05-31-2016, 03:12 PM   #9
pancherj
I agree with the shift point being too low. In addition, you could have some belt slip. Did you log boost pressure going down the track?
Old 05-31-2016, 03:40 PM   #10
camarosspower
Yea that's way to low I agree. I used to shift my ls3 at 7100 rpm. I tried shifting on my own and sometimes it cuts off so I rather not risk it. I did hold 2nd gear to 6k on the first run. But I trapped the same. My cam and geared ls3 was trapping 117. I think 116 is way too low for the l99.
Old 05-31-2016, 03:44 PM   #11
camarosspower
No I didn't log any runs. I guess I'll have to have it checked out when it's on the dyno. But the car feels much slower after the th400 than the 6l80. I have some videos of a pull that I done with the 6l80 and then one with the th400 if y'all would like to see them
Old 05-31-2016, 04:14 PM   #12
pancherj
The gear spread on the TH400 will definitely make it feel slower...especially through first gear. Some lower gears (3.91s maybe?) would probably make a big difference.
You are only adding 23MPH in the last 1/8 mile. That is kind of low for a 600WHP car. That's what made me think belt slip...but the low shift point could also be making a big impact.
Old 05-31-2016, 04:32 PM   #13
camarosspower
Yea there is no belt slippage going on.
Old 05-31-2016, 04:34 PM   #14
camarosspower
Th400
https://m.youtube.com/watch?v=R22YAWuci2A
6l80
https://m.youtube.com/watch?v=6lCxQKn6YGQ
