Old 06-11-2016, 09:53 PM   #1
Jamlive
Drives: 2010 camaro 2ss m6
10 psi safe for regular driving on stock motor ls3?
Exhaust cam car adding in blower
Tvs2300 Magnuson blower
Ati ten rib pulley kit
3.20 front pulley
1.1 cog drive rear
Jannety racing tensioner bracket
Zl1 fuel pump and control module
60lb injectors
Brian tooley stage 3 cam w supporting mods
Long tubes 1 7/8
Straight pipe
1000 hp axles
Looking like it'll make around 10 psi on this setup. Wondering if that's a safe number for regular driving with little racing here and there
Jamlive is offline   Reply With Quote
Old 06-11-2016, 10:36 PM   #2
Unreal
Drives: 2006 Z06
Not without some added octane IMO.
Either meth or e85.
Nick
Corvette Z06 -1200ish rwhp
Old 06-11-2016, 10:47 PM   #3
Jamlive
Was considering adding a boost a pump also. What would be a good methanol kit to consider? Just trying to wrap this install up. Only looking for around 600 hp
Old 06-11-2016, 11:42 PM   #4
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Too much for a PD blower on a stock internal engine if you ask me. I'd say drop the boost. If it were a centri blower then I'd say 8-10 max.
BlaqWhole is offline   Reply With Quote
Old 06-11-2016, 11:46 PM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I daily mine... Stock bottom end ls3, e85, and 19psi here. I think you'll be fine with me that or e85 like stated
ttshovel is offline   Reply With Quote
Old 06-12-2016, 12:42 AM   #6
Jamlive
What about methanol over e85. Not many e85 gas stations here
Old 06-12-2016, 08:20 AM   #7
Unreal
Drives: 2006 Z06
Yes Methanol could work great for the added octane at that level.
Alky Control makes a great kit.
Nick
Old 06-12-2016, 10:17 AM   #8
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Purely oppinion here.
I would run a larger pulley and run about 8 PSI. Only cost you about 40 hp and be a real strong car. Don't get caught up on the number. You'll have a strong car and less issues with the driveline.
UNRIVALED SS is offline   Reply With Quote
Old 06-12-2016, 05:29 PM   #9
old motorhead
Drives: Maggie blown LS3 vette
You can run that rig all day if the tune is good and you have plenty of fuel. You should be right at 10psi. Run it and enjoy!
old motorhead is offline   Reply With Quote
Old 06-13-2016, 12:37 AM   #10
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
I ran 10lbs and nitrous on a PD blower. I was on 93oct. Motor is still strong. No oil loss no problems. Just everything around breaks. Like the drive line lol
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 06-13-2016, 10:22 AM   #11
JANNETTYRACING
JANNETTYRACING's Avatar
3.20 front pulley
1.1 cog drive rear
60lb injectors
Long tubes 1 7/8
Straight pipe
1000 hp axles
Yes it can be done safely with the right injectors and the right tuning.
You do not have enough injector to support your build move to ID-850s.
Thank you for your business.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 06-14-2016, 07:38 PM   #12
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Ive been daily driving mine for years on my setup. Just don't skimp on the fuel system
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 06-15-2016, 09:47 AM   #13
2SSLincolnSS2
SoCal
2SSLincolnSS2's Avatar
Drives: 2011 SS2
I am running 10 lbs with a whipple, dual pass heat exchanger, 850's, rough idle blower cam and make 640 rwhp on 91 octane.It's good to go.
<a href=http://www.camaro5.com/forums/picture.php?albumid=9810&pictureid=82873 target=_blank>http://www.camaro5.com/forums/pictur...ictureid=82873</a>
2SSLincolnSS2 is offline   Reply With Quote
Old 06-15-2016, 09:48 AM   #14
2SSLincolnSS2
SoCal
Drives: 2011 SS2
Of course with the ZL1 pump, I am running out of pressure at commanded 65lbs at high RPM, I am hoping the BAP will fix that; at least until I can put a aftermarket dual pump setup in it.
