Old 06-30-2016, 10:19 AM   #1
Kwilson3.6
Drives: 2016 Camaro 2SS
Shift point?
What's your all shift points in a ls3 car? Manual, tick stage 3 polluter cam and bolt ons.
Kwilson3.6 is offline   Reply With Quote
Old 07-02-2016, 10:31 AM   #2
flyer08
Drives: 2010 2SS/RS
6k? Id keep going
flyer08 is offline   Reply With Quote
Old 07-02-2016, 10:34 AM   #3
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
I shifted at 7k with the nf cam. Made a big difference from 6500 than 7k
camarosspower is offline   Reply With Quote
Old 07-21-2016, 10:06 PM   #4
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
so the car was quicker at 6500? I'm shifting at about 6800
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 07-21-2016, 10:30 PM   #5
camarosspower
Ran harder at 7k
Old 07-21-2016, 10:34 PM   #6
booneSS13
booneSS13's Avatar
Ran harder at 7k
did you ever track a mph difference in the 1/4?
Romans 5:8
Old 07-21-2016, 11:16 PM   #7
camarosspower
2mph
Old 07-22-2016, 08:49 AM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Do you have a dyno sheet? That's what you need to base your information on shift points
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 07-22-2016, 09:17 AM   #9
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
^^^^^^^Ditto
HOJO is offline   Reply With Quote
Old 07-22-2016, 05:47 PM   #10
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Ditto X 2
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 08-04-2016, 02:57 PM   #11
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Ive got the BTR Stage 4 in mine (same as tick LS3 polluter cam) and my limiter is set at 7100.
I used to shift at 6600 that extra 500rpms is definitely a huge difference when you get up to the next gear.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 08-23-2016, 03:54 AM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
7-7100 kill mode.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 08-23-2016, 12:31 PM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Shift points are figured out by experimentation, but you would look at a dyno sheet and start with an educated guess. Which would be driven by peak and average horsepower.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-26-2016, 12:24 AM   #14
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
+1 exactly what PSJ said. Dyno will give you a good place to start then you will have to play around a bit to see what actually works best for your car. Because joe blows car does well shifting at 6800 rpm doesn't mean shit and doesn't mean your setup will work best at that rpm. It might, but, don't take it as carved in stone. Takes some practice, logging, and adjusting to dial it in for your setup.
JD_Alaska is offline   Reply With Quote
