![]() Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
Car keeps dinging after startup
You know how the car dings a few times when you first start it? Well sometimes mine keeps dinging and the only way to make it stop it to shut the car off, pull the key out of the ignition, and open the driver door and restart the car. Any ideas?
Look down at the DIC while it is dinging. What does it say?
It says absolutely nothing. Just the speedo and odometer
Camaro: A Legend Reborn!!
You try resetting by disconnecting the battery? How old is your battery? Charge may be low?
[SIGPIC][/SIGPIC] |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Maybe the door sensor is not seeing that the door is closed sometimes. If it does it again, don't open the door when you turn the car off and crank it back up.
#6 |
I haven't disconnected the battery and as far as age I got the car used. So I assume it's the original battery?
And I'll try not opening the door next time to see if it could be that. Didn't think of that |
#7 |
![]() Drives: 2015 Camaro LS Join Date: Nov 2015
Did you check your passenger seatbelt indicator on the roof console? I once had a refilled propane tank in the passenger seat and it dinged every couple of minutes. It drove me crazy all the way home, I didnt see any errors on the DIC. I even stopped and opened and closed the trunk and both doors. Finally when I was home I realized the car wanted me to buckle up the propane tank.
#8 | |
![]() ![]() Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
I think every Chevy I've owned since 2010 did this from time to time even with no one or anything in the seat. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
It's happened to me a few times, PITA. No rhyme no reason. Had the doors lock on me in my driveway with me nowhere near the key. Possessed b!tch.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
I'm having the same thing happen to me lately. I still have the original battery in my 2010 and it seems to be doing fine. Nothing shows up in the DIC, no flashing lights anywhere either. When the chimes won't stop I turn the car off and restart it and it goes away.
#11 |
![]() ![]() Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
Every now and again mine will ding a few more times than normal upon putting my key in the ignition. But nothing on the DIC or visible issues... it is really random idk what it is but I ignore it.
Sorry OP, I have no answer to your question. |
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
#13 |
#14 |
I keep a jumper box in the trunk in the event the battery does go out on me. I didn't have intentions of replacing until it died. But perhaps it may be worth changing out sooner than later.
