Old 09-02-2016, 11:40 AM   #1
Mr. Texas
Mr. Texas's Avatar
Drives: 2016 Mosiac Black 2SS A8
Low Oil Pressure Message
First off I know there is a TON of threads on this, but the forum is telling me the search function is not working and I'm a little desperate.
2011 Camaro LS3 84k miles
I drove the car last night with no issues and parked it for an hour. I go to start it and get the low oil pressure shut engine off message. I kill the engine and restart it to see if it was a fluke. Sure enough no message this time. I carefully drive it home with no issues. Engine is quiet with no tapping or knocking....
I let the car sit again for an hour restart it and boom message comes up again. I shut it down and have not restarted it yet.
My car is a 1SS so I don't have an oil pressure gauge. What are the odds it is just a sensor? I thought about hooking a manual gauge up to it to see what it reads, but I'm afraid of running the car anymore.
Do I bite the bullet and just replace the pump? It seems what I read on the oil pumps failing most cars had low miles.
Any help or advice is appreciated thanks!
Mr. Texas is offline   Reply With Quote
Old 09-02-2016, 11:59 AM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
You can try to change the sensor, I would personally check it out with a gauge if it were my car. Get ready to buy that oil pump though, it seems likely considering it's not the L99
TommyTheCat is offline   Reply With Quote
Old 09-02-2016, 12:15 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Personally, I would put a manual gauge on it, and pull the ignition on it, to keep it from running. Then see what kind of pressure you have while its cranking. Replacing the sensor is cheap quick and easy.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-02-2016, 12:19 PM   #4
Mr. Texas
Mr. Texas's Avatar
I didn't know if just turning it over with the starter would give me a good enough reading on the pressure. I think I will try that.
Old 09-02-2016, 12:22 PM   #5
1KillerSS
1KillerSS's Avatar
It's not going to be at full pressure, but it will tell you if you have pressure. Then if you have even low pressure while cranking, you can reconnect your ignition and fire it up for a few seconds to see what the pressure is at idle.
Build thread
Old 09-02-2016, 01:31 PM   #6
Mr. Texas
Mr. Texas's Avatar
good call thanks bud!
Old 09-02-2016, 01:50 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
I agree with 1killerss
Mine did the same thing. Had it towed to be safe and thankfully I did. Oil pump went out because the chain tensioner broke. Still got the cam and lifters a little. Changed it all out and she is running good for now.
CHMSC is offline   Reply With Quote
Old 09-02-2016, 03:32 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
There have been a few reported issues with oil pumps failing. Do not run it.
Old 09-02-2016, 06:50 PM   #9
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
Also on our cars you don't actually have to do that. You can just full throttle the pedal, it will crank and not start. ECM disables ignition
Old 09-02-2016, 11:10 PM   #10
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
+1 beat me to it lol
Old 09-03-2016, 12:00 AM   #11
flyinglow57
Drives: rumble bee,2SS 6sp
Oil pump! Just did mine a few months ago. The valve sticks open and dumps all pressure.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
