Old 11-18-2016, 04:11 PM   #1
Matt8892
Drives: 2010 2ss RS. White (RIP) 2012 LS3
Clutch suddenly feels super light, everything functions normally though
So out of no where as I was ready to go at a green light, I depressed the clutch and it felt super light. Like so light I didn't think the clutch was functioning. I eased on the gas and let the clutch our and the car started moving so I drive gently home. Then I drove to work and at first the clutch felt like it's normal stiffness, then it seemed to lighten up as I drove it again.
I'm really starting to wonder if it's in my head or if something is wrong. Any ideas as to why the clutch would suddenly feel super light? A couple weeks ago I added a clutch reservoir and everything felt normal up until today.
Matt8892 is offline   Reply With Quote
Old 11-18-2016, 04:32 PM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
air in lines???
maddoggyusa is offline   Reply With Quote
Old 11-18-2016, 04:36 PM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Sounds like a fluid problem. Have you ever bled your clutch?
Old 11-18-2016, 04:58 PM   #4
Matt8892
Have never bled it. Honestly not sure how to and it sounded like a real pain to do. I've just been swapping the reservoir fluid as it gets dirty in an effort to get as much old fluid out as I can.
Old 11-18-2016, 07:25 PM   #5
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
The reason to swap out the fluid is because it is a magnet for moisture, water. Water is no good for your fluid. When you swap out the fluid at the reservoir only it mixes with all the fluid in the lines and the slave cylinder. This will contaminate the entire system after a couple of pumps with the clutch pedal. This is causing your light clutch. Suck out your reservoir and bleed the system at the slave cylinder until new fluid comes out the slave cylinder bleeder.
Why did you have to change your reservoir in the first place?
Dimitrim is offline   Reply With Quote
Old 11-18-2016, 07:35 PM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
A separate reservoir is preferable, and that reminds me I need to go change my fluid right now......As its a small one so it requires cleaning out fairly often as the hot fluid does dirty up a lot more than brake fluid does over its life and 'with a shared reservoir you have to clean out a lot more fluid' when the fluid turns colors and dirties from the clutch its a fact. Not knowing the miles you have on your engine/clutch too I would change out the fluid pumping repeatedly , and changing again if you do not have a remote bleeder to work up the particulate contamination from the clutch lines that's what you do usually.
Old 11-18-2016, 08:31 PM   #7
JusticePete
You can bleed the slave out without a remote bleeder. It is a pain in the butt and messy, but you need to do it. Once you see clean fluid, use a can of brake clean to clean up the mess in and around the bell housing.
Old 11-18-2016, 08:46 PM   #8
Matt8892
Sorry, should have specified. I added a separate clutch reservoir, that's why I did the work I did. Car has 29k on it. Can anyone provide a quick crash course in bleeding the clutch? I've bled brakes once before, so not to sure how similar it is to that. Is it obvious where the slave cylinder and bleeder is?
Old 11-18-2016, 08:50 PM   #9
JusticePete
You reach it through a rectangular opening at the top of the bell housing. The bleeder is the same as on a caliper. Pump the peddle nd hold it to the floor. Open the bleeder. Let it run. Close it and repeat.
Old 11-18-2016, 09:13 PM   #10
Matt8892
Will tackle this tomorrow and report back. Thanks guys
Old 11-18-2016, 10:36 PM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
interested in hearing the outcome
Old 11-19-2016, 11:19 AM   #12
ytown87
ytown87's Avatar
Drives: C6 Corvette
Swap out to Motul DOT4 fluid. The lines to the clutch/brake fluid run by the trans and when all that gets super hot from being pushed, the pedal can sometimes stick or get light feeling. Happens when you boil the fluid
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 11-19-2016, 03:14 PM   #13
Matt8892
Dot 4 fluid in. Bled 4 times. Going to drive it and report back shortly.
Old 11-20-2016, 09:38 AM   #14
Matt8892
So after driving it all day yesterday after bleeding, the clutch feels amazing. Nice and tight again. Absolutely not stick at the bottom of its travel. The bleeder valve was not that bad to get to at all with a 1/4 inch ratchet and 8mm short socket. The only issue I ran into is after I finished the job while driving, I realized I forgot to put the rubber bleeder cover back on. But other than that, the clutch seems normal now!
