12-11-2016, 08:13 PM | #1 |
Drives: R32 Join Date: Apr 2016
Piston went through the block
Hey guys so right now I'm on the border of suicide right now. I started my LS3 (swapped into 240sx) for the second time and the piston decided it didn't want to stay in the block any longer (see pics of carnage). I have no idea how this even happened. The first time engine started no problem ran roughly for 45 secs (have a video) with no issues.
Engine History: Out of a wrecked '13 SS with only 10K miles and I'm rounding up. I modified the windage tray for the Sikky oil pan to fit per their instructions. A speartech wiring harness was used along with the ECM they provided. Mods: CAI Headers Melling Oil Pump 224/228 .581/.588 112 Comp Cam Supporting Valve train mods Does anybody have any possible scenarios of what could have caused this? The ETC gas pedal was NOT hooked up so overrevving couldn't be a possibility. |
12-11-2016, 08:20 PM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Dang dude, sorry to hear about your luck. Hope everything works out for you
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
12-11-2016, 08:29 PM | #3 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
I would think that detonation occurred and the fuel burnt in the combustion chamber before the piston was at top dead center and the force broke the piston and rod right under the wrist pin
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
12-11-2016, 08:35 PM | #4 |
Also that is the cleanest window I've ever seen in a engine block , I'm not trying to belittle you in any way but I gotta ask ,was there oil and coolant put in the motor? Just looks so clean
12-11-2016, 09:01 PM | #5 |
No worries there is oil and coolant in the engine. Literally, happened almost immediately after turning over. I was in the driver seat and my father was the one whole told me to kill the engine because he saw the explosion.
12-11-2016, 11:04 PM | #6 |
You said the engine is from a prior wrecked car? Perhaps there was some damage you were not aware of, like a hairline stress crack etc.. the LS series motors are pretty solid motors, but in a wreck you never know!
Car mods: never enough!
12-11-2016, 11:53 PM | #7 |
Drives: 2012 Camaro SS2 Ls3 Join Date: Nov 2016
Did it drop a valve or something roll out of the intake into the engine? Pulling heads may tell you what happened.
12-12-2016, 01:37 AM | #8 | |
Planning to pull the engine and rip it apart soon; was planning to remove oil pan and inspect from underneath. I'll pull the valve covers off and inspect in their also. I'll report back with my findings.... |
12-12-2016, 02:36 AM | #9 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Wow........just.........wow...........
That Freaking Blows Pun intended btw........ouch! Man I'm very curious as to how that happened, especially under such "normal" circumstances. Very strange indeed. I wonder what is salvageable from it?
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
12-12-2016, 09:05 AM | #10 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
hydro-lock...looks like fuel leaked into cylinder...also with the mods you list first startup should have been long enough to get motor to operating temp...springs, cam lifters needs a good heat set for long life...seriously blows tho...scoggin dicky has a thread with a LS3 short block...looks nice...Merry Christmas!....peace out...
12-12-2016, 12:16 PM | #11 | |
Seems the only thing that makes sense is prior damage that was invisible to the naked eye from the wreck. BTW, so sorry to hear/see this, TC. Truly wish you the best.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
12-12-2016, 02:44 PM | #12 |
Drives: 2010 Camaro SS Join Date: Oct 2013
Cam Timing?
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
12-12-2016, 02:51 PM | #13 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Check for little nuts and bolts that may have accidentally got into the engine. Did you have the intake off? Seen it happen before where a little but slipped into the intake tract during a mod or rebuild and kaboom. Sad and expensive and frustrating. But it happens.
12-12-2016, 05:23 PM | #14 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
OUCH ,
OLD GUY FLYING FAST AND LOW
