Old 12-26-2016, 07:11 PM   #1
runyonwc
Drives: 2013 ZL1
Long Tube Headers Installed.....Couple questions
I just finished up my header install and I just took it for a ride. First thing, man is it LOUD! I used to have the fuse pulled for the exhaust but I had to put the fuse back in.
About 2 mins of idling, the CEL came on. I did not install cats. Is that normal to come on ao fast?
Next, the black rubber boot on the steerinf shaft is touching the header. Did you guys remove the boot? The shaft itself isnt contact the header just the boot.
Last, the car actually seems a little slower down low and really all over. I assume that is just the tune being off.
runyonwc is offline   Reply With Quote
Old 12-26-2016, 07:25 PM   #2
ram360
Drives: 2012 Camaro ZL1
You need to make adjustments in the tune since you have no rear 02 sensors, etc. Yes that is normal and to be expected. Some headers have a clearance issue with the boot and you can cut that off. Mine had no issues with it in place. You prob lost 1-2psi of boost with the headers. With tuning you will prob pick up 10-20hp after it's all said and done.
2012 Summit White ZL1
Manual (M6)
#38
ram360 is offline   Reply With Quote
Old 12-26-2016, 07:31 PM   #3
runyonwc
Drives: 2013 ZL1
Ok thanks! I hope to get it tuned this week
Old 12-26-2016, 10:06 PM   #4
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
No it's not normal to throw a code for the headers that fast. Check you connections. Something is unplugged. What CEL code is stored? That is also probably why it's not running good.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 12-26-2016, 10:10 PM   #5
runyonwc
Drives: 2013 ZL1
Even with the rear o2s disconnected it wouldnt throw a code that fast? It seems to idle fine and doesnt feel horribly slow, just seems like it lost a little low end torque.
Old 12-26-2016, 10:56 PM   #6
ZO6 Bryan
ZO6 Bryan's Avatar
Well, yes. If you just left the connectors hanging disconnected under there it will throw a code pretty quick.
Old 12-26-2016, 11:29 PM   #7
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Granted I don't have a ZL1, but my CEL came on in under 5 minutes.
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
Old 12-27-2016, 05:40 AM   #8
runyonwc
Drives: 2013 ZL1
Yeah i just zip tied the connectors up out of the way. Would it be better to plug the rear o2 sensor in and then zip tie them? There are no rear bungs
Old 12-27-2016, 05:54 AM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
The CEL can illuminate fairly quickly as the catalytic converter efficiency code will appear if the cats aren't present. I ran my Z/28 with a stock tune and headers and found the CEL light sometimes took 10 min to appear and other times almost immediately after the code was cleared.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:07.59 VIR Full 11.08@126.52 1.76
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-27-2016, 05:58 AM   #10
Stephen12ZL1
Drives: '17 ZL1 A10
this is why the code appeared immediately...open circuit. Once you get a tune, it won't matter. Just leave the rear 02s off.
Old 12-27-2016, 08:35 AM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Are your Headers Coated? I cut mine and wish I had not as I haven't seen any melt yet, but mine is not a DD.
ZMEnow is offline   Reply With Quote
Old 12-27-2016, 09:16 AM   #12
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
When I installed my Kooks, the rubber boot contacted one of the header down tubes, so I decided to cut it off. No issues, especially since I live in AZ and the road conditions are as clean as you can get most of the time.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-27-2016, 09:35 AM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Exactly. If they were plugged in it might be a couple days before the CEL light comes on. It takes awhile for the PCM to run the self tests before it figures out something is off.
After turning off all the secondary O2 codes in the tune it's a non issue.
My Kooks headers have the post cat bungs so I kept everything plugged in. It just seems cleaner even though the PCM ignores them.
Old 12-27-2016, 11:02 AM   #14
runyonwc
Drives: 2013 ZL1
I didnt get the headers coated but i just drove it again ans still the boot hasn't burnt. Maybe it is made of silicone??? Im getting the car tuned tomorrow.
