![]() Drives: 2013 Camaro SS Join Date: Oct 2016
hood heat extractor
I am considering cutting a hood vent in my car. I like the look of them but am admittedly scared of it because it is such a permanent mod. Everything else I have done can be undone, wheels, stripes, interior paint (plastidip) and sill plates can easily be undone if I wanted............ but there is no going back from a hole in the hood. While I like it I also don't want to do it just to do it if that makes sense.
So my question is this does anyone have pics of a yellow Camaro with rally stripes and the single vent in the center of the hood? I tried Google and searching on here but could not find a pic of a car like mine with one which just makes me think even more it will not look right with the rally stripes. |
![]() Drives: 2015 Camaro 1SS M6 Join Date: Nov 2015
Best I could find, Googled "Yellow Camaro"
Let's go fishing!
Drives: a car with 8 cylinders Join Date: Apr 2016
Better be careful about modifying that factory hood... the purist will say it was engineered without one for a reason and you will mess up the down force, cooling, etc.
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
Have you looked into Hex Vents? I had those installed on my Rally Yellow SS w/stripes.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
It definitely improves cooling, the heat pours out Don't be scared it's just a little hole ![]() Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#7 |
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe Join Date: Mar 2016
I think I'd keep the original hood stock and cut up an aftermarket one to put the vents into.
So far I like my car the way it came from the factory.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Red Hot LS3 Join Date: Oct 2014
#9 |
"Elvira"
Drives: 2010 2SS Black with grey stripes Join Date: Apr 2016
Looks bad ass, I like it!
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
#12 |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Oct 2014
If you have no plans of taking your car to the track and really running it hard at high speed then it's just a matter of looks and taste.
However, there's a reason that GM started adding the vents to all SS's and the ZL1s. Heat can be a problem and front end lift on the fifth gens is very real above 100mph! If you want to talk about guts, this guy had an additional vent installed on his brand new 6th gen and while I don't know if the owner plans on tracking it, I think it looks great and definitely functional! This one was manufactured locally and it is made from aluminum. NOT plastic!
"The Beast" 2010 Camaro SS/RS LS3
Diablo T1000 with Phastek custom tune, K&N Intake, Hurst Short-Throw Shifter, Flowmaster, Outlaw II Exhaust, BMR 1" Lowering Springs, BMR 3-way Adjustable Anti-Roll Bars, BMR End Links and Reinforcement Brackets, BMR Trailing Arms, ZL1 wheels, Nitto NT555 G2 Tires, Z28-style Rear Spoiler, Hawk Plus Brake Pads, Motul RBF600 Brake Fluid |
#13 |
![]() Drives: 2012 Orange 2SS/RS Convertible Join Date: May 2016
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I am considering this too, but it is getting the measurements right and everything straight that worries me.
