Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 03-23-2017, 06:41 AM   #1
SSquared
Drives: 2013 1SS/RS
Grounding locations
I have a 70 sbc Camaro and I'm wondering where the ground locations are for the motor / firewall / frame, if any. The battery is grounded to pass side of engine block, lower front. That's all I see.
Thank you for any help you may provide.
PS I don't have any know issues........ Just seems there should be some grounds.
Thanks
SSquared is offline   Reply With Quote
Old 03-23-2017, 08:28 AM   #2
PROZ11
PROZ11's Avatar
Drives: 2012 RS/2SS, 69 ProStreet Camaro
Thanks
Not sure if you are looking for "factory" correct locations. But if not, on my 69 I ran one from the engine to the firewall and one from the engine to the front sub-fame. Probably overkill, but it's cheap insurance. My battery is in the trunk, so my negative cable is run to the frame. Front and rear sub-frames are tied togeather. I obviously didn't need to worry about factory correct.. LOl.
PROZ11 is offline   Reply With Quote
Old 03-28-2017, 05:45 AM   #3
SSquared
Drives: 2013 1SS/RS
Thanks for the infor. I'm going to follow your plan.
