Old 03-28-2017, 07:46 PM   #1
Mr V
Mr V's Avatar
Drives: 2011 VR SS Vert
wind restrictor
I just got my wind restrictor from king penn. I ordered the multicolor version with remote. I have the quick disconnect and the battery pack. My question is wiring it. Searching on the forums make it look like there is a brake light module. That was not listed as an option when I ordered it. Will I need another module to have it on with driving lights and brighter with the brakes on? I will email them tomorrow but since I was working on it thought I would post to see if anyone has already done this.
Thanks,
Mr V
Mr V is offline   Reply With Quote
Old 03-29-2017, 08:24 AM   #2
69 SS 350 5 Speed
69 SS 350 5 Speed's Avatar
Drives: 69 SS Camaro 2019 Corvette GS Vert.
I have the Wind Restrictor in my 2013 Corvette Convertible. I ordered it with the Red LED and wired it to my brake lights.
There is a fine line between hobby and obsession and I think I crossed it!!
69 SS 350 5 Speed is offline   Reply With Quote
Old 03-29-2017, 02:26 PM   #3
Mr V
Mr V's Avatar
I contacted them and found out the brake light module some people had in the past has been discontinued. They are supposed to have a new module coming out in a few weeks so I will probably wait and see what that will run. Without the module the choices are hooking it up to your driving lights and it will be on any time your lights are on. The second is to hook it to your brake lights and will only come on with the brakes. The module should allow me to do what I was looking for, having it work like tail lights, on and then brighter when you hit the brakes.
Old 03-29-2017, 02:48 PM   #4
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Or install it to a switch so you can control when its on, plus you could also install a relay so when you hit the brakes it will be the primary circuit so it will light up regardless of the switch position, this method will of course take more time to research, for me i have it wired to the brake light, to get more interior light i installed some led strips, which also act to illuminate the wind restrictor
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 03-29-2017, 09:30 PM   #5
Mr V
Mr V's Avatar
Interesting. Thanks for replying!
Old 04-22-2017, 05:26 PM   #6
Mr V
Mr V's Avatar
Here is mine
Old 04-23-2017, 07:35 PM   #7
KROLIS
KROLIS's Avatar
Drives: 2017 2LT/RS & 2013 2LT/RS vert
same effect
Do those work the same as ones that mount closer to the front seat?
KROLIS is offline   Reply With Quote
Old 04-23-2017, 09:01 PM   #8
Moreair1
Moreair1's Avatar
They dont work as well as the factory version pictured, But if you need to be able to have a useable back seat with some wind protection this style is the way to go
Old 04-23-2017, 10:07 PM   #9
KROLIS
KROLIS's Avatar
k thx
