![]() Drives: 2012 SS L99 Converible Join Date: Mar 2016
Can ABL be added to dash trim that is painted?
As title states. I have custom painted dash trim that is the solid black plastic under the paint. It use to be fabric. Has anyone added ABL with this sort of painted trim? If so, can you show me pictures?
Here's what my trim looks like
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘13 1LE Join Date: Jul 2013
Unlike the door panels, the dash mounted ABL light output, will be totally dependant on the artificially induced gap(space), that you will introduce on the dash trim, as you re-install it back on the dash.
I have pics of my red dash ABL, posted in a thread here a few years back. |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Yes the light is actually projected onto the gap above the dash pieces not through the dash pieces. Like CamaroDude said, how well it projects is dependant on your gap
OK great! Now second question is that I have the ABL pipe, where's the best place to get the LEDs for them? Dealer???
#6 |
KNGTFALL
Depends on what color you want?
dealer only has red and ice blue. SJM autoprod or Gen5Diy have several color choices. Where did you get the pipe from |
#7 |
Off of a member on here. Gonna check with dealer to see what it will cost me. The oem blue is all I need
#8 |
Ordered them from dealer for $15.34 a piece
#9 |
![]() Drives: 2014 yellow 2SS/RS Join Date: Apr 2015
Did u have a part number to give the dealer or were they able to find it? Do they have the pipe as well? Thanks
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
#10 |
I gave them the part number for the bulb/harness. I don't think the pipe can't be bought separate. Its suppose to come with the inserts as a kit
#11 |
What would the part # be? lol
#12 |
KNGTFALL
92238395
says its silver , but should be blue red is 92228416 |
#13 |
Thanks
#14 |
Yup /\ he's correct on part numbers. I had them double check if by looking up a 2013 Camaro for "door panel insert light" and it was the same number for the blue (or silver as GM calls it).
