Old 05-13-2017, 07:48 PM   #1
Drillteamleader
Drives: 2010 2ssrs
Cam choice?
As of now i have cai, ported tb, long tubes no cats, x pipe and axle back. 2010 ls3. I was looking at gpi ss2 and ss3 cam kits but not sure which to go with. I only drive the car when its nice out and mostly just beat on it. Im not looking for dyno numbers, i want the real world power!!!
Drillteamleader is offline   Reply With Quote
Old 05-13-2017, 08:32 PM   #2
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
SS3.....A member on here broke into the 10's on that cam
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 05-14-2017, 11:03 AM   #3
URDAMAN
URDAMAN's Avatar
Drives: 2010 IBM 2SS / RS
Go bigger SS4...
URDAMAN is offline   Reply With Quote
Old 05-14-2017, 01:55 PM   #4
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
If you really want real world comparisons, smaller cam vs larger cam, side by side race, go to youtube, and you should find SS1 vs SS2 or perhaps SS2 vs SS3, or SS1 vs SS3, I forget lol.
You will see how a smaller cam pulls away first at road legal speeds, but the larger cam pulls away once you hit freeway speeds and higher.
Hope that helps a bit.
Camaro Dude is offline   Reply With Quote
Old 05-14-2017, 03:11 PM   #5
camrytt
camrytt's Avatar
Drives: 2019 1SS
I just asked a similar question, emailed gpi. They talked me into the ss3 over the 2. Talked to PSJ on here too and it sounds like it's fine for daily driving. Gotta get a pretty expensive torque converter to run it tho
Current: 2019 1SS A10
previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears.
Past: '12 LFX, full bolt ons + E85, 302hp/267tq
camrytt is offline   Reply With Quote
Old 05-14-2017, 04:17 PM   #6
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
Im about to put my SS3 in a long with a few other things...
0331Marine is offline   Reply With Quote
Old 05-14-2017, 05:26 PM   #7
avido
Drives: camaro ss\rs
For street use keep the intake duration below 230
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 05-14-2017, 06:08 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Damn...having a big pile of parts to install is a wonderful feeling!
Is that a Wicker Bill spoiler too I see hiding back there!?
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels - Tuned by Ryan @ GPI via HP Tuners
Old 05-15-2017, 04:29 AM   #9
0331Marine
0331Marine's Avatar
Yes sir, hopefully putting it on tomorrow
Old 05-15-2017, 06:25 AM   #10
camrytt
camrytt's Avatar
Drives: 2019 1SS
Damn that's a lot of stuff! Can't wait to see the end result
Old 05-15-2017, 01:37 PM   #11
Drillteamleader
Drives: 2010 2ssrs
Picking up a used set of heads that i will do a little home porting on, and yes i have done several port jobs. It might not be as good as the pros, but it is free hp!!!. Then i will put my stockers on an lq4 build im doing.
Old 05-15-2017, 01:41 PM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I drive mine every day.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Pro Stock John is online now   Reply With Quote
Old 05-15-2017, 01:53 PM   #13
jc615
jc615's Avatar
Drives: Camaro and Sierra
I did the tsp vvt 2 as my first cam and always wanted more power. Ended up adding the ss4 last summer since gpi didn't have a line out back then. Go bigger cause you'll def want more power
jc615 is offline   Reply With Quote
Old 05-15-2017, 04:32 PM   #14
Drillteamleader
Drives: 2010 2ssrs
My main question between cams was more depending on that have the 6 speed. Since launching these cars is such a pain in the ass. It would be nice to be able to put 15's and slicks on, but im not going to spend that kind of money for that.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
