Old 06-27-2017, 10:24 PM   #1
sdmaro
Drives: 2011 LS Camaro
Emergency... trunk issue :(
Was doing header work and disconnected the negative terminal. Left the spare tire at a 45 degree angle and i have a huge sub enclosure behind it. Brother closed the trunk accidently and now I can't open the trunk or better yet start my car.... any tips? Will jumper cables in the engine terminals allow me to pop the trunk?
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline   Reply With Quote
Old 06-27-2017, 10:26 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Yes. No problem. You can even use a battery charger.
Are you bigger than your brother?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 06-27-2017, 10:36 PM   #3
sdmaro
So jumper cables should be good? Yeah, i'm 5'10 160 and he's 5'8 120
Old 06-27-2017, 11:57 PM   #4
CamaroFred
CamaroFred's Avatar
Better off with the soft charge. Won't ruin you battery like jumpers.
The smart ones today know how much and when to charge.
2011 1SS/RS LS3 CGM
Old 06-28-2017, 02:20 AM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Pull the back (vertical part) of the rear seat down, crawl into the trunk and pull the T shaped handle to release it manually. Find someone small and give them a flashlight.
Since the negative terminal is off the battery, hooking jumper cables up won't allow you to open the trunk. The whole system is ungrounded.
Old 06-28-2017, 03:34 AM   #6
CamaroFred
CamaroFred's Avatar
If you do or if you don't have a battery in the trunk when you connect jumper cables you have a hot and a ground.
You don't need to crawl into the trunk.
There is a terminal covered with a red plastic and an uncovered terminal on the left side of the engine bay. The one with the cover is the positive, with a Plus sign on it, the uncovered one by the air cleaner is the negative (ground).
2011 1SS/RS LS3 CGM
Old 06-28-2017, 07:18 AM   #7
ron123
ron123's Avatar
Drives: 2014 2SS/RS
The Camaro Engineers planned for just such an emergency and provided a manual trunk lid release on the underside of the lid partly for that reason.
Just work the handle loose and let the cable hang down, then once the handle is free from the lid, pull down.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 06-28-2017, 08:28 AM   #8
Abelardoo_12
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
Im assuming you can't crawl into the trunk through the back seat due to way you left the spare tire ? Either way all you have to do is use jumper cables through the terminals under the hood to have power and just use the button to open the trunk, you dont have to start the car like that just to open the trunk
Abelardoo_12 is offline   Reply With Quote
Old 06-28-2017, 08:49 AM   #9
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
I am not sure if coupes have the same as convertibles but in mine there is a key cylinder in the back seat on the drivers side. You put the ignition key in it and turn to the left to open trunk.
Hope this helps.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 06-28-2017, 09:41 AM   #10
jrhagen
Banned
Drives: Camaro
The entire back seat comes out in 5 minutes. Lots of room to do what you need.
jrhagen is offline   Reply With Quote
Old 06-28-2017, 09:46 AM   #11
sdmaro
Sub enclosure covers entire trunk so I can't just climb into the trunk. Plus in the OP the spare tire was blocking me from manuvering the subwoofer. Jumper cables worked. Thanks guys.
Old 06-28-2017, 10:09 AM   #12
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
super surprised the cables worked with negative disconnected!
now we know!
DvKillar is offline   Reply With Quote
Old 06-28-2017, 12:30 PM   #13
Netraa
Drives: 2014 2ss/rs
now we know!
The car was not grounded right up until he put the jumper cables on the negative terminal... this grounded the car through the cable to the other vehicle's ground.
I would not suggest trying to start a car like this, but it will hold enough current to pop the trunk.
Netraa is offline   Reply With Quote
Old 06-28-2017, 01:38 PM   #14
DvKillar
DvKillar's Avatar
Nice!
