![]() Drives: 2010 SS Join Date: Feb 2017
Anvil Spoiler Install Question
I just ordered a Spoiler, anyone have any issuses on the install, or is it a clean unbolt the old and re bolt the new?
TIA |
![]() Drives: 2SS RS Join Date: Jul 2009
Mine was a quick / clean swap from stock to Anvil. Took about 5 mins.
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I did have to open up one of my holes just a hair. Was NOT an issue and has been looking for years.
Think I had to open up 2 holes on mine a little . Not bad.
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Mine went in no trouble.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘13 1LE Join Date: Jul 2013
Had to open up a couple of holes with the ol drill.
This is common enough with the Anvil installation procedure. For some, this may be a butt puckering experience. |
#7 |
#8 |
Make sure to have some touch up paint on hand to touch up the hole/s after you open it up a little. You don't want any exposed raw metal .
#9 |
#10 |
I found the end pads are junk and on a hot day the glue turns to mush allowing the pad to shift. I'll be replacing mine with a better quality.
#11 |
It is a good looking spoiler for sure! It was my second pick had I not went with the Spoiler5.
#12 |
Tri-County Camaro SWFL
The holes don't quite line up 100%. Like others have said. Have touch up paint on standby after you open up some of the holes.
#13 |
![]() Drives: 2011 Camaro SS Join Date: May 2014
Idk about others but the "wings" of the anvil were rubbing really bad on the body of the car. Wish I had caught it sooner as it did do some damage after only a couple days :(. The pads didnt do much if anything to prevent it. I had to max out the rubber stoppers for the trunk way up to avoid rubbing. Just something to keep in mind!
#14 |
the pads on mine are still stuck on for what its worth. Clean the bottom of the spoiler where the pads go with alcohol before sticking them on.
