Old 08-04-2017, 11:40 PM   #1
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Hood not sitting flush? Help?
Not sure what happened here.. or when or how.
I've had my hood sit either above the bumper line or below when messing with the bumper stops under the hood near radiator shroud, however I have not had the figment and body lines he off.
What I did do recently is switch from CAI Intake to RotoFab (not one to usually say this, but I noticed a difference and I was a loyal CAI fan) and am thinking, since Intake is on driver side that maybe that is sitting too high causing this issue. Not sure.
In any event, here's some pics to show each side. I've tried raising bumpers on passenger side and lowering on drivers side and still can't seem to make it fit right.
Granted, it's not noticeable to naked eye (looks worse on pics) but like us all, I know it's there.
Any help in troubleshooting is appreciated -
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 08-05-2017, 10:14 PM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Looks like it's the cai causing this. I would remove the cai and modify that instead of trying to make the car adapt to the cai.
You could also adjust the latch on the front support if you like.
I like the paint , is that PPG "Prizmatique"?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 08-08-2017, 11:24 PM   #3
TwentyTen2SSRS
Drives: 2010 2SS/RS
Thanks I can't figure it out the CAI is all the way in and flush how it should fit, confirmed with roto fab as well. I may just leave it as it's not very noticeable unless looking for it.
Old 08-09-2017, 08:53 AM   #4
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Post some pics of that awesome looking car.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 08-09-2017, 10:26 AM   #5
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
you can use the little rubber bumpers when you open the hood to raise it a bit to flush it out.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 08-09-2017, 08:32 PM   #6
TheFlyingBananaSS
If the hood was flush before the cai then it's obviously the cai that's causing the misalignment. An old trick is to put some chalk on the cai high spots then close the hood. Open the hood again and if the cai is rubbing on the underside of the hood the chalk will transfer where ever it's touching the cai. Then just slowly trim the high spots down until the hood sits flush again. Or remount the cai and see if it was in how it's mounted that may be causing it.
Old 08-09-2017, 09:39 PM   #7
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
make sure your hood hinges are lubed up and that the hinge isn't binding
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 08-10-2017, 12:15 PM   #8
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Im thinking its a wrap, not paint...
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is online now   Reply With Quote
Old 08-14-2017, 06:14 PM   #9
TwentyTen2SSRS
Drives: 2010 2SS/RS
Not a wrap - well the CF is obviously
Old 08-14-2017, 06:15 PM   #10
TwentyTen2SSRS
Drives: 2010 2SS/RS
Thanks guys I'll try the chalk trick and see whats up. Don't usually ever have an issue
Old 08-15-2017, 05:21 AM   #11
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Make sure the box is seated properly on the underside pin.
2015 ZL1 M6
PJMZL1 is offline   Reply With Quote
Old 08-17-2017, 09:13 PM   #12
TheFlyingBananaSS
This too
Old 10-06-2017, 11:38 PM   #13
TwentyTen2SSRS
Drives: 2010 2SS/RS
Thanks guys I think gonna have to take Intake out and re install
