Old 08-19-2017, 09:52 PM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
Ok need help please ?
So ,my right low beam head like gos out after about 30-45 seconds of begging turned on.. Not sure if it's a bad bulb or ballast ? Any suggestions ?? And if it's a ballast do I need to take out the front pumper and light housing ?? Thanks
Scotty D is offline   Reply With Quote
Old 08-19-2017, 10:44 PM   #2
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
I would guess the bulb is bad if once it heats up it shuts off.
Talladega is offline   Reply With Quote
Old 08-19-2017, 10:51 PM   #3
Scotty D
Ahh ok I'll try that first then go from there ! Thanks
Old 08-21-2017, 09:09 AM   #4
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
The bulb is easy to check. Just swap from the other side. Be careful not to touch the bulbs. Like Talladega said though, it's more than likely your bulb. Now you can replace it and match the 5000k color of your halos!
Junior is offline   Reply With Quote
