Old 11-04-2009, 04:22 PM   #1
montej23
montej23's Avatar
Drives: 2011 VR Camaro
Exclamation K&N Air Filter
Has anyone had issues with the Airfilter from K&N? For some reason my stock airfilter when in allowed me to average 27mpg yet when i put this K&N Airfilter in i dropped to 21mpg.
My driving pattern has not changed.. my gas octaine has changed... does anyone have any ideas or have this issue? Id like to fix it besides replacing the airfilter to stock. It just doesnt seam right. Any IDEAS
montej23 is offline   Reply With Quote
Old 11-05-2009, 08:13 AM   #2
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
I gained 2 mpg when I installed the K&N Air Filter back 3 months ago and now that I drive in "S" mode consistently I'm in the 23-24 mpg range for my 60 mile roundtrip daily commute (70% secondary roads, 30% highway). I did run 89 octane for a while but saw no benefit then switched back to 87 with no issues.
When was your last oil change ? Was it around the same time you changed to the K&N?
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 11-05-2009, 08:19 AM   #3
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Before I put in my new K&N filter I carefully dried up as much of the oil as I could. I believe the stock K&N filter comes with too much oil and can affect the Mass air flow transmitter.
tradosaurus is offline   Reply With Quote
Old 11-05-2009, 09:49 AM   #4
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
This is a very good idea to do. Thats one of the reason why I only use oil-less filters...
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-09-2009, 07:21 PM   #5
dlynds
Drives: 2010 2LT RS inferno Orange
I installed a Airaid intake and filter and noticed my mpgs got worse. What can you do to clean or remove the filter's oil that has already hit the mass sensor and fix the problem? The intake was a heafty investment for me and I want to get all it's benifits.
Thanks.
dlynds is offline   Reply With Quote
Old 11-09-2009, 07:45 PM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Thanks.
Check at the local auto parts store for some MAF sensor cleaning spray....
Pull your MAF sensor out and spray, following the directions on the can...
scrming is offline   Reply With Quote
Old 11-09-2009, 07:47 PM   #7
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
- X
I could not agree more.
Old 11-09-2009, 07:53 PM   #8
dlynds
Thanks, I'll try it tomorrow!
Old 11-10-2009, 11:23 AM   #9
montej23
montej23's Avatar
all good info i will do this as well and let you know what happens probably wont get a chance to do it for a couple days.
Old 11-10-2009, 02:47 PM   #10
Airaid Filters
Airaid Filters's Avatar
Drives: 2010 Camaro
Thanks.
Hello dlynds,
There is no reason to clean the MAF sensor.
The Airaid Premium Filter is designed with 4 layers of cotton gauze and incorporates a 5th layer of Synthetic material on the inside that WILL NOT ALLOW ANY OIL TO PENETRATE THROUGH THE FILTER.
Do not listen to the dealer when they tell you there is filter "oil" on the MAF sensor, when using a Airaid Premium Filter. If the dealer insists, ask them to "TEST" the MAF sensor!
Gains or loses in MPG are all dependant on driving styles and driving conditions. A less restrictive air filter does not reduce MPG.
Thanks,
David
Airaid Filters is offline   Reply With Quote
Old 11-13-2009, 06:10 PM   #11
rauhaus camaro
SoCal C5 Family Member
rauhaus camaro's Avatar
Drives: 2010 Black Camaro 2SS with LS3
You might try resetting your ECM to relearn your AFR. You can try pulling your #5 and #20 fuses before you turn in at night then reinstall them in the morning. The other option is to just let the engine relearn on its own. It does that when the mass air flow sensor climbs or adjusts to different altitudes, low desert to high mountains, etc.
rauhaus camaro is offline   Reply With Quote
Old 11-14-2009, 11:26 PM   #12
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
Colder temps will affect your mpgs too.
PieNsky is offline   Reply With Quote
Old 11-15-2009, 12:30 AM   #13
5thGenCamaroChick
Hey y'all :)
5thGenCamaroChick's Avatar
Drives: Rosalee
You might check your tire pressure. When the temps drop it causes the air in your tires to contract. Lower psi causes lower mpgs. You prolly already know this, just thought I'd mention it just in case you didn't. Btw, I have a 1lt with a k&n filter, no probs with the gas mileage.
"Are you picking up what I'm laying down? Can you dig what I'm growing?"
5thGenCamaroChick is offline   Reply With Quote
Old 11-15-2009, 02:22 AM   #14
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Another thing that really effects gas mileage this time of year is that most
cities require that the gas be oxygenated from Oct. or Nov. to Apr or May.
So they put around 10 percent ethanol in the gas. Look at the pump and you'll probably see a sticker that the fuel is oxygenated. There is less energy
in a gallon of this fuel, so gas mileage drops accordingly. The price should drop also, but it never does. My mileage dropped about 3 mpg's on my SS
when they did this in the Denver area.
In the spring you'll see it go back up. Hope this helps you.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 262 02-14-2019 01:07 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 08:33 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 02:11 AM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 03:34 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
