![]() Drives: 2015 Black Camaro 2SS Join Date: Aug 2017
Exhaust leaks
I installed headers over the weekend with stock exhaust. Anyways I have band clamps and the exhaust still leaks. One leak is at the collector and i was wondering if maybe there is a sweet spot it should be at. She it be close to the header flange or further away?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
What headers?.....cats?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
I got some exhaust tape from o'riley and wrapped it around the seam, then put the clamp over it. Completely stopped the leak. Fyi, I tried different clamps, adjusted them too... no luck, the tape and a ss band clamp solved it.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
I was able to fix it. The clamps were assembled wrong out the package. After I assembled them right they tightened right up and no more leaks.
![]() Drives: 2012 2SS 45th Anniversary Edition Join Date: Mar 2017
That is a great idea which headers do you have. I have speed engineering and the leak in making ma nuts
#6 |
I have the speed engineering also... take the clamps off. Apply the tape. Install the clamps. Run the car long enough to heat it up good...short trip. Go back and tighten the clamps.... when there still hot.
#7 | |
![]() Drives: 2015 Camaro 1SS Join Date: Oct 2017
2015 Camaro 1SS
Air Raid CAI Speed Engineering Long Tube Headers 1994 Pontiac Trans Am GT (Non OP) |
#8 | |
![]() Drives: 2015 SS/A6 Join Date: Feb 2016
going to try and remedy this weekend with the same clamps
2015 Camaro SS/A6--Roxy MOD'S
*Rear Muffler Delete *VMAX Throttle Body *Speed-Engineering Headers / No Cats *Catted Magnaflow X-Pipe *BMR Toe Rods *BMR Xtreme Ant-Roll Kit *BMR Trailing Arms *CAI Cold Air Intake *TUNED BY JAY @ KRAFTSWORKS EXCELL |
#9 |
How'd it go with the clamps? It seems mine keep loosening and the leak always manages to come back. I've also noticed it is now leaking from the mid-pipe to the factory exhaust. I re-used the stock clamp, everywhere I've read said that should be fine but now that's leaking too. Really debating take the headers off now, I can't stand driving around with all the whistling..
2015 Camaro 1SS
